Datasheet JM1AN-TMP-DC5V-F - Panasonic Даташит Мощное реле, 5 В постоянный ток, 20 А, SPST-NO, PCB — Даташит
Наименование модели: JM1AN-TMP-DC5V-F
![]() 7 предложений от 7 поставщиков Промышленные/Универсальные Реле, Electromechanical Relay 5VDC 27.8Ω 20A SPST-NO (30.4x16x36.5)mm Top Mount Power Relay | |||
JM1-ANTMPDC5VF Panasonic | 189 ₽ | ||
JM1-ANTMPDC5VF Panasonic | 276 ₽ | ||
JM1AN-TMP-DC5V-F Panasonic | 282 ₽ | ||
JM1AN-TMP-DC5V-F Panasonic | по запросу |
Производитель: Panasonic
Описание: Мощное реле, 5 В постоянный ток, 20 А, SPST-NO, PCB
JM
Ideal for compressor and motor control Inrush 80A, 1a 20A power relay
VDE
JM RELAYS
· Conforms to the various safety standards UL, CSA, VDE available · The line up can support economical mounting methods.
The relay are equipped with a drive terminal (coil terminal) on one side for PCBs, and a load terminal (tab terminal #250) on the reverse side. The line up includes the TM type which can be attached directly to the PCB composing a drive circuit, and the TMP type which supports economical wiring. The TMP type can also be directly attached, and a high capacity load can be wired to the tab terminal.
- Тип реле: Power
- Coil Voltage VDC Nom: 5 В
- Contact Current Max: 20 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 5 В
- Coil Resistance: 27.8 Ом
- Конфигурация контактов: SPST-NO
- Coil Type: DC
JM1ANTMPDC5VF, JM1AN TMP DC5V F
