Datasheet NC2EBD-DC24V - Panasonic Даташит POWERE реле, 24 В постоянный ток, 3 А, DPDT, PLUG-IN — Даташит
Наименование модели: NC2EBD-DC24V
20 предложений от 11 поставщиков
Реле Мощности, Electromechanical Relay 24VDC 1.6KΩ 5ADC/3AAC DPDT (( 25.4mm 11.2mm 27.8mm)) Socket Power Relay
NC2EBD-DC24V
Panasonic
261 ₽
NC2EBD-DC24V
Panasonic
1 930 ₽
NC2EBD-DC24V
Panasonic
от 2 051 ₽
Эиком
NC2EBD-DC24V
Panasonic
от 2 227 ₽
АЦП азиатских производителей
Производитель: Panasonic
Описание: POWERE реле, 24 В постоянный ток, 3 А, DPDT, PLUG-IN
data sheetСкачать Data Sheet
NC
Transistor drive 2c/4c 5A slim power relays
NC RELAYS
TYPICAL APPLICATIONS
1.
Information processing and telecom equipment such as computers and terminal devices. 2. Gas hot air heating equipment and air conditioners. 3. Timer, temperature controller and other equipment that requires form factor reduction. 4. Transmission and measuring devices such as facsimile machines and electronic counting devices. 5. Control panels for industrial equipment such as machine tools, factory automation devices, and NC machines.
  • Тип реле: Power
  • Coil Voltage VDC Nom: 24 В
  • Contact Current Max: 3 А
  • Contact Voltage AC Nom: 250 В
  • Contact Voltage DC Nom: 30 В
  • Coil Resistance: 1.6 кОм
  • Конфигурация контактов: DPDT
  • Coil Type: DC
NC2EBDDC24V, NC2EBD DC24V
На английском языке: Datasheet NC2EBD-DC24V - Panasonic POWERE RELAY, 24 V DC, 3 A, DPDT, PLUG-IN
