Datasheet NC2EBD-P-DC24V - Panasonic Даташит Мощное реле, 24 В постоянный ток, 3 А, DPDT, PCB — Даташит
Наименование модели: NC2EBD-P-DC24V
![]() 21 предложений от 10 поставщиков Реле Мощности, Power/Signal Relay, DPDT, Momentary, 0.015A (Coil), 24VDC (Coil), 360mW (Coil), 5A (Contact), DC Input, AC-DC Output, Through Hole-Straight Mount,... | |||
NC2EBD-P-DC24V Panasonic | 726 ₽ | ||
NC2EBD-P-DC24V Matsushita | 1 876 ₽ | ||
NC2EBD-P-DC24V Panasonic | от 2 282 ₽ | ||
NC2EBD-P-DC24V Panasonic | по запросу |
Производитель: Panasonic
Описание: Мощное реле, 24 В постоянный ток, 3 А, DPDT, PCB
NC
Transistor drive 2c/4c 5A slim power relays
NC RELAYS
TYPICAL APPLICATIONS
1.
Information processing and telecom equipment such as computers and terminal devices. 2. Gas hot air heating equipment and air conditioners. 3. Timer, temperature controller and other equipment that requires form factor reduction. 4. Transmission and measuring devices such as facsimile machines and electronic counting devices. 5. Control panels for industrial equipment such as machine tools, factory automation devices, and NC machines.
- Тип реле: Power
- Coil Voltage VDC Nom: 24 В
- Contact Current Max: 3 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 1.6 кОм
- Конфигурация контактов: DPDT
- Coil Type: DC
NC2EBDPDC24V, NC2EBD P DC24V
