Datasheet NC4D-JP-DC5V - Panasonic Даташит Мощное реле, 5 В постоянный ток, 5 А, 4PDT, PCB — Даташит
Наименование модели: NC4D-JP-DC5V
![]() 24 предложений от 11 поставщиков Реле Мощности, Power Relay 5VDC 4A 4PDT (( 38.1mm 28.34mm 10.9mm)) Through Hole | |||
NC4D-JP-DC5V Panasonic | 590 ₽ | ||
NC4D-JP-DC5V Panasonic | 1 213 ₽ | ||
NC4D-JP-DC5V Panasonic | по запросу |
Производитель: Panasonic
Описание: Мощное реле, 5 В постоянный ток, 5 А, 4PDT, PCB
NC
Transistor drive 2c/4c 5A slim power relays
NC RELAYS
TYPICAL APPLICATIONS
1.
Information processing and telecom equipment such as computers and terminal devices. 2. Gas hot air heating equipment and air conditioners. 3. Timer, temperature controller and other equipment that requires form factor reduction. 4. Transmission and measuring devices such as facsimile machines and electronic counting devices. 5. Control panels for industrial equipment such as machine tools, factory automation devices, and NC machines.
- Тип реле: Power
- Coil Voltage VDC Nom: 5 В
- Contact Current Max: 5 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 34.7 Ом
- Конфигурация контактов: 4PDT
- Coil Type: DC
NC4DJPDC5V, NC4D JP DC5V
