Datasheet S2EB-48V - Panasonic Даташит Мощное реле, 48 В постоянный ток, 4 А, DPS-NO / DPST-NC, PCB — Даташит
Наименование модели: S2EB-48V
![]() 25 предложений от 12 поставщиков Реле Мощности, Relays 48VDC 8.5KΩ 3ADC/4AAC DPST-NO/DPST-NC(28mm 12mm 10.4mm) THT General Purpose Relay | |||
S2EB-48V Panasonic | 1 549 ₽ | ||
S2EB-48V Panasonic | от 2 202 ₽ | ||
S2EB-48V Panasonic | по запросу | ||
S2EB-48V | по запросу |
Производитель: Panasonic
Описание: Мощное реле, 48 В постоянный ток, 4 А, DPS-NO / DPST-NC, PCB
S
2a2b/3a1b/4a 4A polarized power relays
S RELAYS
7.
Low thermal electromotive force relay High sensitivity (low power consumption) is realized by 4G-BA technology. Separation of the coil and spring sections has resulted in a relay with extremely low levels of thermal electromotive force (approx. 0.3 µV). 8. DIL terminal array Deployed to fit a 2.54 mm .100 inch grid, the terminals are presented in DIL arrays which match the printed circuit board terminal patterns commonly in international use. 9. Relays that push the boundaries of relay efficiency High-density S relays take you close to the limits of relay efficiency. 10. Sockets are available.
Compliance with RoHS Directive
- Тип реле: Polarized
- Coil Voltage VDC Nom: 48 В
- Contact Current Max: 4 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 8.5 кОм
S2EB48V, S2EB 48V
