Datasheet SP2-P-DC5V - Panasonic Даташит Мощное реле, 5 В постоянный ток, 15 А, DPDT, PCB — Даташит
Наименование модели: SP2-P-DC5V
![]() 17 предложений от 10 поставщиков Реле Мощности, Electromechanical Relay DPDT 10ADC/15AAC 5VDC 83Ω Through Hole | |||
SP2-P-DC5V Panasonic | от 3 673 ₽ | ||
SP2-P-DC5V Panasonic | от 3 988 ₽ | ||
SP2-P-DC5V | по запросу | ||
SP2-P-DC5V Panasonic | по запросу |
Производитель: Panasonic
Описание: Мощное реле, 5 В постоянный ток, 15 А, DPDT, PCB
SP
2c 15A, 4c 10A polarized power relays
SP RELAYS
FEATURES
1.
Small, slim form factor Facilitating the form factor reduction of devices, the overall height of the relay package is less than half that of our HP relay. 2. High sensitivity The high-efficiency polarized electromagnetic mechanism in conjunction with our exclusive spring alignment method achieves levels of sensitivity higher than relays that have been available up to now. For both the 2 Form C and 4 Form C single side stable and 2 coil latching types, the 150 mW minimum operating power level allows direct driving by transistor or chip controllers. 3. High reliability and long life With a structure that ensures almost perfectly complete twin contact and minimal contact bounce, you get greater reliability than has so far been provided by power relays. 4. Latching types also available 1 coil latching and 2 coil latching types are available. In cases where it was formerly unavoidable to use plural relays for large power memory
- Тип реле: Polarized
- Coil Voltage VDC Nom: 5 В
- Contact Current Max: 15 А
- Contact Voltage AC Nom: 250 В
- Contact Voltage DC Nom: 30 В
- Coil Resistance: 83 Ом
- Конфигурация контактов: DPDT
- Coil Type: DC
SP2PDC5V, SP2 P DC5V
