Линейка продуктов KEEN SIDE
Datasheet ST1-L2-DC12V-F - Panasonic Даташит Мощное реле, 12 В постоянный ток, 8 А, SPST-NO / SPST-NC, PCB — Даташит
Наименование модели: ST1-L2-DC12V-F
22 предложений от 9 поставщиков
Реле Мощности, Power Relay 12VDC 8A SPST-NO/SPST-NC (31mm 14mm 11.3mm) THT
ST1-L2-DC12V-F
Panasonic
263 ₽
ST1-L2-DC12V-F
Panasonic
713 ₽
ST1-L2-DC12V-F
Panasonic
1 316 ₽
ST1-L2-DC12V-F
Panasonic
1 356 ₽
АЦП азиатских производителей
Производитель: Panasonic
Описание: Мощное реле, 12 В постоянный ток, 8 А, SPST-NO / SPST-NC, PCB
data sheetСкачать Data Sheet
VDE
ST
1a1b/2a 8A polarized power relays
ST RELAYS
6.
Automatic cleaning possible The sealed design means that these relays can undergo immersion in automatic washing systems and are suitable for automatic soldering. Even in difficult environments, the contacts remain reliable. 7. Easy to design PC board patterns Features 4/10 dual-in-line terminals. Because the lead spacing has a pitch greater than 7.54 mm .297 inch, designers can make easy adjustments with the width of the land size. This, along with the large insulation distance, simplifies the drawing of PC board patterns. 8. To improve soldering efficiency, preapplication of solder to the terminals is recommended. 9. Sockets are available.
  • Тип реле: Polarized
  • Coil Voltage VDC Nom: 12 В
  • Contact Current Max: 8 А
  • Contact Voltage AC Nom: 380 В
  • Contact Voltage DC Nom: 250 В
  • Coil Resistance: 640 Ом
ST1L2DC12VF, ST1 L2 DC12V F
На английском языке: Datasheet ST1-L2-DC12V-F - Panasonic POWER RELAY, 12 V DC, 8 A, SPST-NO / SPST-NC, PCB
