Datasheet ST2-DC5V-F - Panasonic Даташит Реле, мощность, 5 В постоянный ток, 8 А, DPST, PCB — Даташит
Наименование модели: ST2-DC5V-F
![]() 27 предложений от 12 поставщиков Универсальное реле, серия ST, силовое, без защелки, DPST, 5В DC, 8А | |||
ST2-DC5V-F Matsushita | 1 101 ₽ | ||
ST2-DC5V-F Panasonic | от 1 461 ₽ | ||
ST2-DC5V-F Panasonic | от 1 565 ₽ | ||
ST2-DC5V-F Panasonic | по запросу |
Производитель: Panasonic
Описание: Реле, мощность, 5 В постоянный ток, 8 А, DPST, PCB
VDE
ST
1a1b/2a 8A polarized power relays
ST RELAYS
6.
Automatic cleaning possible The sealed design means that these relays can undergo immersion in automatic washing systems and are suitable for automatic soldering. Even in difficult environments, the contacts remain reliable. 7. Easy to design PC board patterns Features 4/10 dual-in-line terminals. Because the lead spacing has a pitch greater than 7.54 mm .297 inch, designers can make easy adjustments with the width of the land size. This, along with the large insulation distance, simplifies the drawing of PC board patterns. 8. To improve soldering efficiency, preapplication of solder to the terminals is recommended. 9. Sockets are available.
- Coil Current: 47 мА
- Coil Resistance: 105 Ом
- Coil Type: DC, Monostable
- Coil Voltage VDC Nom: 5 В
- Contact Current Max: 8 А
- Contact Voltage AC Nom: 380 В
- Contact Voltage DC Nom: 250 В
- External Depth: 31 мм
- Operating Power Nom: 240 мВт
- Внешняя ширина: 14 мм
- Габариты: высота: 11.3 мм
- Конфигурация контактов: DPST-NO
- Способ монтажа: PCB
- Тип реле: Power
- RoHS: да
ST2DC5VF, ST2 DC5V F
