Datasheet ADA4930-2YCPZ - Analog Devices Даташит ИС, усилитель, DIFF, 1.35GHZ, 24-LFCSP — Даташит
Analog Devices ADA4930-2YCPZ
Наименование модели: ADA4930-2YCPZ
34 предложений от 18 поставщиков
ADA4930-2YCPZ-R7
от 292 ₽
ADA4930-2YCPZ-R7
487 ₽
ADA4930-2YCPZ-RL
760 ₽
Microfind
ADA4930-2YCPZ-R7
2 001 ₽
Производитель: Analog Devices
Описание: ИС, усилитель, DIFF, 1.35GHZ, 24-LFCSP
data sheetСкачать Data Sheet
Ultralow Noise Drivers for Low Voltage ADCs ADA4930-1/ADA4930-2
FEATURES
Low input voltage noise: 1.2 nV/Hz Low common-mode output: 0.9 V on single supply Extremely low harmonic distortion -104 dBc HD2 at 10 MHz -79 dBc HD2 at 70 MHz -73 dBc HD2 at 100 MHz -101 dBc HD3 at 10 MHz -82 dBc HD3 at 70 MHz -75 dBc HD3 at 100 MHz High speed -3 dB bandwidth of 1.35 GHz, G = 1 Slew rate: 3400 V/s, 25% to 75% 0.1 dB gain flatness to 380 MHz Fast overdrive recovery of 1.5 ns 0.5 mV typical offset voltage Externally adjustable gain Differential-to-differential or single-ended-to-differential operation Adjustable output common-mode voltage Single-supply operation: 3.3 V or 5 V
100
FUNCTIONAL BLOCK DIAGRAMS
  • Input Offset Voltage: 350 мкВ
  • Slew Rate: 3400 В/мкс
  • Диапазон напряжения питания: 3.3 В, 5 В
  • Amplifier Case Style: LFCSP
  • Количество выводов: 24
ADA49302YCPZ, ADA4930 2YCPZ
На английском языке: Datasheet ADA4930-2YCPZ - Analog Devices IC, AMP, DIFF, 1.35GHZ, 24-LFCSP
