Datasheet CA3102MZ - Intersil Даташит ИС DIFFERENTIAL усилитель, DUAL, L POWER — Даташит
Наименование модели: CA3102MZ
Купить CA3102MZ на РадиоЛоцман.Цены — от 64 до 158 ₽10 предложений от 10 поставщиков Микросхема Буферный усилитель, Trans RF BJT NPN 15V 0.05A 14Pin SOIC N | |||
| CA3102MZ Intersil | 64 ₽ | ||
| CA3102MZ Intersil | по запросу | ||
| CA3102MZ Renesas | по запросу | ||
Производитель: Intersil
Описание: ИС DIFFERENTIAL усилитель, DUAL, L POWER
CA3102
Data Sheet October 12, 2005 FN611.7
Dual High Frequency Differential Amplifier For Low Power Applications Up to 500MHz
The CA3102 consists of two independent differential amplifiers with associated constant current transistors on a common monolithic substrate.
The six transistors which comprise the amplifiers are general purpose devices which exhibit low 1/f noise and a value of fT in excess of 1GHz. These features make the CA3102 useful from DC to 500MHz. Bias and load resistors have been omitted to provide maximum application flexibility. The monolithic construction of the CA3102 provides close electrical and thermal matching of the amplifiers. This feature makes this device particularly useful in dual channel applications where matched performance of the two channels is required. The CA3102 has a separate substrate connection for greater design flexibility.
- Number of Amplifiers: 2
- Input Offset Voltage: 5 мВ
- Amplifier Case Style: SOIC
- Количество выводов: 14
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: SOIC
- Семейство: 3102
- Gain Bandwidth: 1.35GHz
- Input Offset Voltage Max: 5 мВ
- Рабочий диапазон температрур: -55°C ... +125°C
- Напряжение питания номинальное: 15 В
- Способ монтажа: SMD
- Тип ОУ: Low Power
Дополнительные аксессуары:
- BONKOTE - BON102
- Fischer Elektronik - ICK SMD A 5 SA
- Roth Elektronik - RE932-03
