Datasheet LMH6554LEE - National Semiconductor Даташит ИС, усилитель, DIFF, 2.8 ГГц, 14LLP — Даташит
Наименование модели: LMH6554LEE
Купить LMH6554LEE на РадиоЛоцман.Цены — от 178 до 1 736 ₽35 предложений от 18 поставщиков Микросхема Операционный усилитель, TEXAS INSTRUMENTS LMH6554LEE/NOPB Differential Amplifier, Ultra Linear, 1 Amplifiers, -6.5mV, 2.8GHz, -40℃, 125℃ | |||
| LMH6554LEE Texas Instruments | 452 ₽ | ||
| LMH6554LEE/NOPB Texas Instruments | 760 ₽ | ||
| LMH6554LEE/NOPB Texas Instruments | от 1 173 ₽ | ||
| LMH6554LEE National Semiconductor | по запросу | ||
Описание: ИС, усилитель, DIFF, 2.8 ГГц, 14LLP
LMH6554 2.8 GHz Ultra Linear Fully Differential Amplifier
September 9, 2010
General Description
The LMH6554 is a high performance fully differential amplifier designed to provide the exceptional signal fidelity and wide large-signal bandwidth necessary for driving 8 to 16 bit high speed data acquisition systems.
Using National's proprietary differential current mode input stage architecture, the LMH6554 has unity gain, small-signal bandwidth of 2.8 GHz and allows operation at gains greater than unity without sacrificing response flatness, bandwidth, harmonic distortion, or output noise performance. The device's low impedance differential output is designed to drive ADC inputs and any intermediate filter stage. The LMH6554 delivers 16-bit linearity up to 75 MHz when driving 2V peak-to-peak into loads as low as 200. The LMH6554 is fabricated in National Semiconductor's advanced complementary BiCMOS process and is available in a
- Количество усилителей: 1
- Напряжение смещения входа: -6.5 мВ
- Коэффициент усиления максимальный: 1 дБ
- Полоса частот: 2.8 ГГц
- Скорость нарастания: 6200 В/мкс
- Диапазон напряжения питания: 4.7 В ... 5.25 В
- Ток потребления: 52 мА
- Тип корпуса: LLP
- Количество выводов: 14
- Рабочий диапазон температрур: -40°C ... +125°C
- SVHC: No SVHC (19-Dec-2011)
