Datasheet LT1990CS8 - Linear Technology Даташит ИС, SM, OP усилитель, DIFF — Даташит
Наименование модели: LT1990CS8
 Купить LT1990CS8 на РадиоЛоцман.Цены — от 12 до 482 ₽43 предложений от 20 поставщиков Микросхема Операционный усилитель, LINEAR TECHNOLOGY LT1990CS8#PBF Differential Amplifier, Micropower, 1 Amplifiers, 5.2mV, 10dB, 100kHz, -40℃, 85℃  | |||
| LT1990CS8#PBF Linear Technology  | 12 ₽ | ||
| LT1990CS8#PBF | 291 ₽ | ||
| LT1990CS8 | 411 ₽ | ||
| LT1990CS8 Analog Devices  | 448 ₽ | ||
Производитель: Linear Technology
Описание: ИС, SM, OP усилитель, DIFF
LT1990 ±250V Input Range G = 1, 10, Micropower, Difference Amplifier DESCRIPTIO
The LT®1990 is a micropower precision difference amplifier with a very high common mode input voltage range.
It has pin selectable gains of 1 or 10. The LT1990 operates over a ±250V common mode voltage range on a ±15V supply. The inputs are fault protected from common mode voltage transients up to ±350V and differential voltages up to ±500V. The LT1990 is ideally suited for both high side and low side current or voltage monitoring. On a single 5V supply, the LT1990 has an adjustable 85V input range, 70dB min CMRR and draws less than 120µA supply current. The rail-to-rail output maximizes the dynamic range, especially important for single supplies as low as 2.7V. The LT1990 is specified for single 3V, 5V and ±15V supplies over both commercial and industrial temperature ranges. The LT1990 is available in the 8-pin SO package.
, LT, LTC and LTM are registered trademarks of Linear Technology Corporation. All ot
- Количество усилителей: 1
 - Input Offset Voltage: 5.2 мВ
 - Gain dB Max: 10 дБ
 - Полоса частот: 0.1 МГц
 - Slew Rate: 0.5 В/мкс
 - Диапазон напряжения питания: 2.7 В ... 36 В
 - Ток потребления: 140 мкА
 - Amplifier Case Style: SOIC
 - Количество выводов: 8
 - SVHC: No SVHC (15-Dec-2010)
 - Тип корпуса: SOIC
 - Тип усилителя: Operational
 - Семейство: 1990
 - Input Offset Voltage Max: 3 мВ
 - Рабочий диапазон температрур: -40°C ... +85°C
 - Напряжение питания номинальное: 18 В
 - Способ монтажа: SMD
 - Gain Bandwidth: 100 кГц
 - Вход / выход: Rail-Rail Outputs
 - Тип ОУ: Precision
Дополнительные аксессуары:
- Roth Elektronik - RE932-01
 - STANNOL - 631954
