Datasheet LT1994CDD - Linear Technology Даташит Operational Amplifier (Op-Amp) ИС — Даташит
Наименование модели: LT1994CDD
Производитель: Linear Technology
Описание: Operational Amplifier (Op-Amp) ИС
LT1994 Low Noise, Low Distortion Fully Differential Input/ Output Amplifier/Driver FEATURES
DESCRIPTIO
Fully Differential Input and Output Wide Supply Range: 2.375V to 12.6V Rail-to-Rail Output Swing Low Noise: 3nV/Hz Low Distortion, 2VP-P, 1MHz: 94dBc Adjustable Output Common Mode Voltage Unity Gain Stable Gain-Bandwidth: 70MHz Slew Rate: 65V/s Large Output Current: 85mA DC Voltage Offset <2mV MAX Open-Loop Gain: 100V/mV Low Power Shutdown 8-Pin MSOP or 3mm Ч 3mm DFN Package
The LT®1994 is a high precision, very low noise, low distortion, fully differential input/output amplifier optimized for 3V, single supply operation.
The LT1994's output common mode voltage is independent of the input common mode voltage, and is adjustable by applying a voltage on the VOCM pin. A separate internal common mode feedback path provides accurate output phase balancing and reduced even-order harmonics. This makes the LT1994 ideal for level shifting ground referenced signals for driving
- Количество усилителей: 1
- Input Offset Voltage: 3 мВ
- Полоса частот: 70 МГц
- Slew Rate: 65 В/мкс
- Диапазон напряжения питания: 2.375 В ... 12.6 В
- Ток потребления: 14.8 мА
- Amplifier Case Style: DFN
- Количество выводов: 8
Дополнительные аксессуары:
- Linear Technology - LTC2258CUJ-14#PBF
- Linear Technology - LTC2258IUJ-14#PBF
