Datasheet LTC6420CUDC-20 - Linear Technology Даташит ИС, DIFF усилитель, 1.8 ГГц, 4500 В/мкс, QFN-20 — Даташит
Linear Technology LTC6420CUDC-20
Наименование модели: LTC6420CUDC-20
Микросхема Буферный усилитель, LINEAR TECHNOLOGY LTC6420CUDC-20#TRPBF Differential Amplifier, Low Distortion, 2 Amplifiers, 400μV, 1.8GHz, 0 °C, 70℃
525 ₽
LTC6420CUDC-20#PBF
1 049 ₽
727GS
TradeElectronics
LTC6420CUDC-20#PBF
Производитель: Linear Technology
Описание: ИС, DIFF усилитель, 1.8 ГГц, 4500 В/мкс, QFN-20
data sheetСкачать Data Sheet
FEATURES
n n n n n n n n n n n n n n
LTC6420-20 Dual Matched 1.8GHz Differential Amplifiers/ADC Drivers DESCRIPTION
The LTC®6420-20 is a dual high-speed differential amplifier targeted at processing signals from DC to 300MHz.
The part has been specifically designed to drive 12-, 14- and 16-bit ADCs with low noise and low distortion, but can also be used as a general-purpose broadband gain block. The LTC6420-20 is easy to use, with minimal support circuitry required. The output common mode voltage is set using an external pin, independent of the inputs, which eliminates the need for transformers or AC-coupling capacitors in many applications. The gain is internally fixed at 20dB (10V/V). The LTC6420-20 saves space and power compared to alternative solutions using IF gain blocks and transformers. The LTC6420-20 is packaged in a compact 20-lead 3mm Ч 4mm QFN package and operates over the ­40°C to 85°C temperature range.
L, LT, LTC and LTM are registered trademarks of Linear Technology Co
  • Количество усилителей: 2
  • Напряжение смещения входа: 2 мВ
  • Коэффициент усиления максимальный: 20 дБ
  • Полоса частот: 1.8 ГГц
  • Скорость нарастания: 4500 В/мкс
  • Диапазон напряжения питания: 2.85 В ... 3.5 В
  • Ток потребления: 80 мА
  • Тип корпуса: QFN
LTC6420CUDC20, LTC6420CUDC 20
На английском языке: Datasheet LTC6420CUDC-20 - Linear Technology IC, DIFF AMP, 1.8 GHz, 4500 V/µs, QFN-20
