Datasheet ТI THS4509RGTT — Даташит
СерияTHS4509
МодельTHS4509RGTT
Datasheet Texas Instruments THS4509RGTT
Широкополосный операционный усилитель 16-VQFN от -40 до 85
THS4509 Wideband, Low-Noise, Low-Distortion, Fully-Differential Amplifier datasheet
PDF, 2.2 Мб, Версия: I, Файл опубликован: 29 июл 2016
  • Output impedance matching with fully differential operational amplifiers
    PDF, 747 Кб, Файл опубликован: 11 мар 2009
  • Low-power, high-intercept interface to the ADS5424, 105-MSPS converter
    PDF, 478 Кб, Файл опубликован: 10 окт 2005
  • Fully differential amplifiers applications:Line termination,driving high-speed..
    PDF, 255 Кб, Файл опубликован: 2 мар 2005
  • Using fully differential op amps as attenuators, Part 3
    PDF, 568 Кб, Файл опубликован: 4 окт 2009
  • Using fully differential op amps as attenuators, Part 2
    PDF, 531 Кб, Файл опубликован: 14 июл 2009
  • Design for a Wideband Differential Transimpedance DAC Output (Rev. A)
    PDF, 438 Кб, Версия: A, Файл опубликован: 17 окт 2016
    High-speed digital-to-analog converters commonly offer a complementary current output signal. Most output interface implementations use either a resistive load and/or a transformer to convert this current source signal to a voltage. Where a dc-coupled interface is required, a carefully designed differential transimpedance stage can offer an attractive alternative. Design considerations and options
  • Analysis of fully differential amplifiers
    PDF, 295 Кб, Файл опубликован: 11 мар 2005
  • Q3 2009 Issue Analog Applications Journal
    PDF, 2.1 Мб, Файл опубликован: 14 июл 2009
  • Fully-Differential Amplifiers (Rev. E)
    PDF, 867 Кб, Версия: E, Файл опубликован: 19 сен 2016
    Differential signaling has been commonly used in audio, data transmission, and telephone systems for many years because of its inherent resistance to external noise sources. Today, differential signaling is becoming popular in high-speed data acquisition, where the ADC’s inputs are differential and a differential amplifier is needed to properly drive them.Two other advantages of di
  • Q1 2009 Issue Analog Applications Journal
    PDF, 1.4 Мб, Файл опубликован: 11 мар 2009
  • Q4 2009 Issue Analog Applications Journal
    PDF, 1.5 Мб, Файл опубликован: 4 окт 2009
  • Driving High-Speed ADCs: Circuit Topologies and System-Level Parameters (Rev. A)
    PDF, 327 Кб, Версия: A, Файл опубликован: 10 сен 2010
    This application report discusses the performance-related aspects of passive and active interfaces at the analog input of high-speed pipeline analog-to-digital converters (ADCs). The report simplifies the many possibilities into two main categories: passive and active interface circuits. The first section of the report gives an overview of equivalent models of buffered and unbuffered ADC input cir
Серия: THS4509 (4)
На английском языке: Datasheet Texas Instruments THS4509RGTT
Политика конфиденциальности
