Datasheet LMH6551MA/NOPB - National Semiconductor Даташит ИС, DIFF усилитель, 370 МГц, 2400 В/мкс, SOIC-8 — Даташит
National Semiconductor LMH6551MA/NOPB
Наименование модели: LMH6551MA/NOPB
30 предложений от 20 поставщиков
Рутоника
LMH6551MA/NOPB
187 ₽
Эиком
LMH6551MA/NOPB
824 ₽
LMH6551MA/NOPB
LMH6551MA/NOPB
Описание: ИС, DIFF усилитель, 370 МГц, 2400 В/мкс, SOIC-8
data sheetСкачать Data Sheet
LMH6551 Differential, High Speed Op Amp
February 2005
General Description
The LMHTM6551 is a high performance voltage feedback differential amplifier.
The LMH6551 has the high speed and low distortion necessary for driving high performance ADCs as well as the current handling capability to drive signals over balanced transmission lines like CAT 5 data cables. The LMH6551 can handle a wide range of video and data formats. With external gain set resistors, the LMH6551 can be used at any desired gain. Gain flexibility coupled with high speed makes the LMH6551 suitable for use as an IF amplifier in high performance communications equipment. The LMH6551 is available in the space saving SOIC and MSOP packages.
  • Количество усилителей: 1
  • Input Offset Voltage: 6 мВ
  • Полоса частот: 370 МГц
  • Slew Rate: 2400 В/мкс
  • Диапазон напряжения питания: 3 В ... 12 В
  • Ток потребления: 12.5 мА
  • Amplifier Case Style: SOIC
  • Количество выводов: 8
На английском языке: Datasheet LMH6551MA/NOPB - National Semiconductor IC, DIFF AMP, 370 MHz, 2400 V/µs, SOIC-8
