Datasheet LMH6552MA/NOPB - National Semiconductor Даташит ИС, DIFF усилитель, 1.5GHZ, 3800 В/мкс, SOIC-8 — Даташит
Наименование модели: LMH6552MA/NOPB
![]() 28 предложений от 15 поставщиков Интегральные микросхемы Аналоговая техника — усилители — инструменты, ОУ (операционные), буферные | |||
LMH6552MA/NOPB Texas Instruments | 273 ₽ | ||
LMH6552MA/NOPB Texas Instruments | 662 ₽ | ||
LMH6552MA/NOPB Texas Instruments | 1 219 ₽ | ||
LMH6552MA/NOPB Texas Instruments | 1 325 ₽ |
Описание: ИС, DIFF усилитель, 1.5GHZ, 3800 В/мкс, SOIC-8
LMH6552 1.5 GHz Fully Differential Amplifier
September 2007
General Description
The LMH6552 is a high performance fully differential amplifier designed to provide the exceptional signal fidelity and wide large-signal bandwidth necessary for driving 8 to 14 bit high speed data acquisition systems.
Using National's proprietary differential current mode input stage architecture, the LMH6552 allows operation at gains greater than unity without sacrificing response flatness, bandwidth, harmonic distortion, or output noise performance. With external gain set resistors and integrated common mode feedback, the LMH6552 can be configured as either a differential input to differential output or single ended input to differential output gain block. The LMH6552 can be AC or DC coupled at the input which makes it suitable for a wide range of applications including communication systems and high speed oscilloscope front ends. The performance of the LMH65
- Количество усилителей: 1
- Input Offset Voltage: 16.5 мВ
- Полоса частот: 1.5GHz
- Slew Rate: 3800 В/мкс
- Диапазон напряжения питания: 4.5 В ... 12 В
- Ток потребления: 22.5 мА
- Amplifier Case Style: SOIC
- Количество выводов: 8
