Datasheet LMH6553SDE/NOPB - National Semiconductor Даташит Differential Amplifier ИС — Даташит
National Semiconductor LMH6553SDE/NOPB
Наименование модели: LMH6553SDE/NOPB
28 предложений от 15 поставщиков
LMH6553SDE/NOPB
263 ₽
Зенер
Россия и страны ТС
LMH6553SDE/NOPB
от 456 ₽
LMH6553SDE/NOPB
678 ₽
LMH6553SDE/NOPB
Описание: Differential Amplifier ИС
data sheetСкачать Data Sheet
LMH6553 900 MHz Fully Differential Amplifier With Output Limiting Clamp
October 13, 2010
General Description
The LMH6553 is a 900 MHz differential amplifier with an integrated adjustable output limiting clamp.
The clamp increases system performance and provides transient over-voltage protection to following stages. The internal clamp feature of the LMH6553 reduces or eliminates the need for external discrete overload protection networks. When used to drive ADCs, the amplifier's output clamp allows low voltage ADC inputs to be protected from being overdriven and damaged by large input signals appearing at the system input. Fast overdrive recovery of 600 ps ensures the amplifier output rapidly recovers from a clamping event and quickly resumes to follow the input signal. The LMH6553 delivers exceptional bandwidth, distortion, and noise performance ideal for driving ADCs up to 14-bits. The LMH6553 could also be used
На английском языке: Datasheet LMH6553SDE/NOPB - National Semiconductor Differential Amplifier IC
