Datasheet LMP8270MA - National Semiconductor Даташит ИС, усилитель DIFF, SMD, SOIC8, 8270 — Даташит
National Semiconductor LMP8270MA
Наименование модели: LMP8270MA
17 предложений от 17 поставщиков
IC OPAMP DIFF 1 CIRCUIT 8SOIC. Differential Amplifier 1 Circuit Rail-to-Rail 8-SOIC. Linear - Amplifiers - Instrumentation, OP Amps, Buffer Amps...
Элитан
LMP8270MA
39 ₽
LMP8270MA/NOPB
64 ₽
LMP8270MA/NOPB
462 ₽
LMP8270MA
Описание: ИС, усилитель DIFF, SMD, SOIC8, 8270
data sheetСкачать Data Sheet
LMP8270 High Common Mode, Gain of 20, Precision Voltage Difference Amplifier
January 2007
General Description
The LMP8270 is a fixed gain differential amplifier with a -2V to 16V input common mode voltage range and a supply voltage range of 4.75V to 5.5V.
The LMP8270 is part of the LMP® precision amplifier family which will detect, amplify and filter small differential signals in the presence of high common mode voltages. The gain is fixed at 20 and is adequate to drive an ADC to full scale in most cases. This gain is achieved in two stages, a preamplifier with a fixed gain of 10 and a second stage amplifier with a fixed gain of 2. The internal signal path between these two stages is brought out on two pins, A1 and A2, which provide a connection for a filter network. The LMP8270 will function over an extended common mode input voltage range making the device suitable for applications with load dump events su
Данные для моделированияДанные для моделирования
  • Количество усилителей: 1
  • Gain dB Max: 20.2 дБ
  • Полоса частот: 80 кГц
  • Количество выводов: 8
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: SOIC
  • Семейство: 8270
  • Input Offset Voltage Max: 1 мВ
  • Рабочий диапазон температрур: -40°C ... +125°C
  • Slew Rate: 0.7 В/мкс
  • Способ монтажа: SMD
  • Диапазон напряжения питания: 4.75 В ... 5.5 В
Дополнительные аксессуары:
  • Fischer Elektronik - ICK SMD A 8 SA
  • Roth Elektronik - RE932-01
  • STANNOL - 574601
На английском языке: Datasheet LMP8270MA - National Semiconductor IC, AMP DIFF, SMD, SOIC8, 8270
