Datasheet LMP8271MA - National Semiconductor Даташит ИС, усилитель DIFF, SMD, SOIC8, 8271 — Даташит
National Semiconductor LMP8271MA
Наименование модели: LMP8271MA
IC OPAMP DIFF 1 CIRCUIT 8SOIC. Differential Amplifier 1 Circuit Rail-to-Rail 8-SOIC. Linear - Amplifiers - Instrumentation, OP Amps, Buffer Amps...
LMP8271MA
24 ₽
SUV System
LMP8271MA/NOPB
LMP8271MA/NOPB
LMP8271MA/NOPB
Описание: ИС, усилитель DIFF, SMD, SOIC8, 8271
data sheetСкачать Data Sheet
LMP8271 High Common Mode, Gain of 20, Bidirectional Precision Voltage Difference Amplifier
January 2007
General Description
The LMP8271 is a fixed gain differential amplifier with a -2V to 16V input common mode voltage range and a supply voltage range of 4.75V to 5.5V.
The LMP8271 is part of the LMP® precision amplifier family which will detect, amplify and filter small differential signals in the presence of high common mode voltages. The gain is fixed at 20 and is adequate to drive an ADC to full scale in most cases. This fixed gain is achieved in two separate stages, a preamplifier with gain of +10 and a second stage amplifier with a gain of +2. The internal signal path is brought out on two pins that provide a connection for a filter network. The LMP8271 will function over an extended common mode input voltage range making the device suitable for applications with load dump events such as a
Данные для моделированияДанные для моделирования
  • Количество усилителей: 1
  • Input Offset Voltage: 1 мВ
  • Gain dB Max: 20.2 дБ
  • Полоса частот: 80 кГц
  • Slew Rate: 0.7 В/мкс
  • Диапазон напряжения питания: 4.75 В ... 5.5 В
  • Ток потребления: 1 мА
  • Amplifier Case Style: SOIC
  • Количество выводов: 8
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: SOIC
  • Семейство: 8271
  • Input Offset Voltage Max: 1 мВ
  • Рабочий диапазон температрур: -40°C ... +125°C
  • Способ монтажа: SMD
Дополнительные аксессуары:
  • Fischer Elektronik - ICK SMD A 8 SA
  • Roth Elektronik - RE932-01
  • STANNOL - 631954
На английском языке: Datasheet LMP8271MA - National Semiconductor IC, AMP DIFF, SMD, SOIC8, 8271
