Datasheet LMP8272MA - National Semiconductor Даташит ИС, усилитель DIFF, SMD, SOIC8, 8272 — Даташит
Наименование модели: LMP8272MA
Купить LMP8272MA на РадиоЛоцман.Цены — от 46 до 418 ₽25 предложений от 19 поставщиков Интегральные микросхемы Аналоговая техника — усилители — инструменты, ОУ (операционные), буферные | |||
| LMP8272MA Texas Instruments | от 140 ₽ | ||
| LMP8272MA/NOPB Texas Instruments | 346 ₽ | ||
| LMP8272MA/NOPB Texas Instruments | по запросу | ||
| LMP8272MA/NOPB National Semiconductor | по запросу | ||
Описание: ИС, усилитель DIFF, SMD, SOIC8, 8272
LMP8272 High Common Mode, Gain of 14, Precision Voltage Difference Amplifier
January 2007
General Description
The LMP8272 is a fixed gain differential amplifier with a -2V to 16V input common mode voltage range and a supply voltage range of 4.75V to 5.5V.
The LMP8272 is part of the LMP® precision amplifier family which will detect, amplify, and filter small differential signals in the presence of high common mode voltages. The gain is fixed at 14 and is adequate to drive an ADC to full scale in most cases. This fixed gain is achieved in two separate stages, a pre-amplifier with gain of +7 and a second stage amplifier with a gain of +2. The internal signal path between these two stages is brought out on two pins that provide a connection for a filter network. The LMP8272 will function over an extended common mode input voltage range making the device suitable for applications with load dump events such as aut
- Количество усилителей: 1
- Gain dB Max: 14.14 дБ
- Полоса частот: 25 МГц
- Количество выводов: 8
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: SOIC
- Семейство: 8272
- Input Offset Voltage Max: 1 мВ
- Рабочий диапазон температрур: -40°C ... +125°C
- Slew Rate: 0.7 В/мкс
- Способ монтажа: SMD
- Диапазон напряжения питания: 4.75 В ... 5.5 В
Дополнительные аксессуары:
- Fischer Elektronik - ICK SMD A 8 SA
- Roth Elektronik - RE932-01
- STANNOL - 574601
