Datasheet LT6411IUD - Linear Technology Даташит усилитель, DIFF ADC, DRIVER, DUAL, QFN-16 — Даташит
Наименование модели: LT6411IUD
![]() 38 предложений от 18 поставщиков Интегральные микросхемы Аналоговая техника — усилители — инструменты, ОУ (операционные), буферные | |||
LT6411IUD Analog Devices | 810 ₽ | ||
LT6411IUD PBF Linear Technology | по запросу | ||
LT6411IUD#TRPBF Linear Technology | по запросу | ||
Производитель: Linear Technology
Описание: Усилитель, DIFF ADC, DRIVER, DUAL, QFN-16
FEATURES
LT6411 650MHz Differential ADC Driver/Dual Selectable Gain Amplifier DESCRIPTION
The LT®6411 is a dual amplifier with individually selectable gains of +1, +2 and 1.
The amplifiers have excellent distortion performance for driving ADCs as well as excellent bandwidth and slew rate for video, data transmission and other high speed applications. Single-ended to differential conversion with a system gain of 2 is particularly straightforward by configuring one amplifier with a gain of +1 and the other amplifier with a gain of 1. The LT6411 can be used on split supplies as large as ±6V and on a single supply as low as 4.5V. Each amplifier draws only 8mA of quiescent current when enabled. When disabled, the output pins become high impedance and each amplifier draws less than 350µA. The LT6411 is manufactured on Linear Technology's proprietary, low voltage, complimentary, bipolar process and is available in the ultra-compact, 3mm Ч 3mm, 16pin QFN package.
, LT, LTC a
- Количество усилителей: 2
- Input Offset Voltage: 10 мВ
- Gain dB Max: 2 дБ
- Полоса частот: 650 МГц
- Slew Rate: 3300 В/мкс
- Диапазон напряжения питания: 2.25 В ... 6.3 В
- Ток потребления: 8 мА
- Amplifier Case Style: QFN
- Количество выводов: 16
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: QFN
- Тип усилителя: Gain
- Семейство: 6411
- Input Offset Voltage Max: 20 мВ
- Рабочий диапазон температрур: -40°C ... +85°C
- Напряжение питания номинальное: 12.6 В
- Способ монтажа: SMD
