Datasheet LTC1992-5CMS8 - Linear Technology Даташит ИС, SM, OP усилитель, DIFF — Даташит
Наименование модели: LTC1992-5CMS8
Купить LTC1992-5CMS8 на РадиоЛоцман.Цены — от 160 до 1 821 ₽15 предложений от 15 поставщиков IC OPAMP DIFF 1 CIRCUIT 8MSOP. Differential Amplifier 1 Circuit Differential, Rail-to-Rail 8-MSOP. Linear - Amplifiers - Instrumentation, OP Amps, Buffer... | |||
| LTC1992-5CMS8#TRPBF Analog Devices | 160 ₽ | ||
| LTC1992-5CMS8#PBF Analog Devices | 282 ₽ | ||
| LTC1992-5CMS8#TRPBF | 433 ₽ | ||
| LTC1992-5CMS8#PBF Linear Technology | по запросу | ||
Производитель: Linear Technology
Описание: ИС, SM, OP усилитель, DIFF
LTC1992 Family Low Power, Fully Differential Input/Output Amplifier/Driver Family
FEATURES
DESCRIPTIO
Adjustable Gain and Fixed Gain Blocks of 1, 2, 5 and 10 ±0.3% (Max) Gain Error from 40°C to 85°C 3.5ppm/°C Gain Temperature Coefficient 5ppm Gain Long Term Stability Fully Differential Input and Output CLOAD Stable up to 10,000pF Adjustable Output Common Mode Voltage Rail-to-Rail Output Swing Low Supply Current: 1mA (Max) High Output Current: 10mA (Min) Specified on a Single 2.7V to ±5V Supply DC Offset Voltage <2.5mV (Max) Available in 8-Lead MSOP Package
The LTC®1992 product family consists of five fully differential, low power amplifiers.
The LTC1992 is an unconstrained fully differential amplifier. The LTC1992-1, LTC1992-2, LTC1992-5 and LTC1992-10 are fixed gain blocks (with gains of 1, 2, 5 and 10 respectively) featuring precision on-chip resistors for accurate and ultrastable gain. All of the LTC1992 parts have a separate internal common mode feedback path for
- Количество усилителей: 1
- Input Offset Voltage: 2.5 мВ
- Полоса частот: 3.5 МГц
- Slew Rate: 2 В/мкс
- Диапазон напряжения питания: 2.7 В ... 11 В
- Ток потребления: 800 мкА
- Amplifier Case Style: MSOP
- Количество выводов: 8
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: MSOP
- Тип усилителя: Operational
- Семейство: 1992
- Input Offset Voltage Max: 4 мВ
- Рабочий диапазон температрур: -40°C ... +85°C
- Напряжение питания номинальное: 6 В
- Способ монтажа: SMD
- Conversion Time: 1 мкс
- Gain Bandwidth: 4 МГц
- Вход / выход: Fully Differential
- Тип ОУ: Low Power
Дополнительные аксессуары:
- Fischer Elektronik - ICK SMD A 10 SA
- Roth Elektronik - RE903
- STANNOL - 631954
LTC19925CMS8, LTC1992 5CMS8
