Datasheet LT1101SW - Linear Technology Даташит ИС, SM, OP усилитель, INSTR — Даташит
Наименование модели: LT1101SW
![]() 31 предложений от 19 поставщиков Микросхема Усилитель прибора, INST Amp 1 ±22V/44V 16Pin SOIC W | |||
LT1101SW#PBF Analog Devices | 384 ₽ | ||
LT1101SW#PBF Analog Devices | от 1 850 ₽ | ||
LT1101SW#TR | по запросу | ||
LT1101SW#PBF Linear Technology | по запросу |
Производитель: Linear Technology
Описание: ИС, SM, OP усилитель, INSTR
LT1101 Precision, Micropower, Single Supply Instrumentation Amplifier (Fixed Gain = 10 or 100) DESCRIPTIO
The LT®1101 establishes the following milestones: (1) It is the first micropower instrumentation amplifier, (2) It is the first single supply instrumentation amplifier, (3) It is the first instrumentation amplifier to feature fixed gains of 10 and/or 100 in low cost, space-saving 8-lead packages.
The LT1101 is completely self-contained: no external gain setting resistor is required. The LT1101 combines its micropower operation (75µA supply current) with a gain error of 0.008%, gain linearity of 3ppm, gain drift of 1ppm/°C. The output is guaranteed to drive a 2k load to ±10V with excellent gain accuracy. Other precision specifications are also outstanding: 50µV input offset voltage, 130pA input offset current, and low drift (0.4µV/°C and 0.7pA/°C). In addition, unlike other instrumentation amplifiers, there is no output offset voltage contribution to total error. A full set of speci
- Количество усилителей: 1
- Input Offset Voltage: 600 мкВ
- Gain dB Min: 10 дБ
- Gain dB Max: 100 дБ
- Полоса частот: 35 МГц
- Тип выхода: Differential
- CMRR: 112 дБ
- Slew Rate: 0.07 В/мкс
- Диапазон напряжения питания: ± 1.1 В ... ± 18 В
- Ток потребления: 100 мкА
- Amplifier Case Style: SOIC
- Количество выводов: 16
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: SOIC
- Тип усилителя: Operational
- Семейство: 1101
- Gain Bandwidth: 33 кГц
- Input Offset Drift Max: 0.4µV/°C
- Input Offset Voltage Max: 0.9 мВ
- Рабочий диапазон температрур: 0°C ... +70°C
- Тип выхода: Single Ended
- Напряжение питания номинальное: 20 В
- Способ монтажа: SMD
Дополнительные аксессуары:
- Fischer Elektronik - ICK SMD A 10 SA
- Roth Elektronik - RE932-04
- STANNOL - 631954
