Datasheet LT1102CN8 - Linear Technology Даташит ИС, OP усилитель, INSTR, DIP8, 1102 — Даташит
Наименование модели: LT1102CN8
![]() 38 предложений от 19 поставщиков Микросхема Буферный усилитель, LINEAR TECHNOLOGY LT1102CN8#PBF Instrument Amplifier, 1 Amplifier, 900µV, 30V/µs, 220kHz, ± 9V to ± 18V, DIP | |||
LT1102CN8#PBF Analog Devices | 321 ₽ | ||
LT1102CN8#PBF Linear Technology | 409 ₽ | ||
LT1102CN8#PBF | 922 ₽ | ||
LT1102CN8#PBF Analog Devices | 1 093 ₽ |
Производитель: Linear Technology
Описание: ИС, OP усилитель, INSTR, DIP8, 1102
LT1102 High Speed, Precision, JFET Input Instrumentation Amplifier (Fixed Gain = 10 or 100)
FEATURES
DESCRIPTIO
Slew Rate: 30V/µs Gain-Bandwidth Product: 35MHz Settling Time (0.01%): 3µs Overdrive Recovery: 0.4µs Gain Error: 0.05% Max Gain Drift: 5ppm/°C Gain Nonlinearity: 16ppm Max Offset Voltage (Input + Output): 600µV Max Drift with Temperature: 2µV/°C Input Bias Current: 40pA Max Input Offset Current: 40pA Max Drift with Temperature (to 70°C): 0.5pA/°C
The LT ®1102 is the first fast FET input instrumentation amplifier offered in the low cost, space saving 8-pin packages.
Fixed gains of 10 and 100 are provided with excellent gain accuracy (0.01%) and non-linearity (3ppm). No external gain setting resistor is required. Slew rate, settling time, gain-bandwidth product, overdrive recovery time are all improved compared to competitive high speed instrumentation amplifiers. Industry best speed performance is combined with impressive precision specifications: less than
- Количество усилителей: 1
- Input Offset Voltage: 900 мкВ
- Gain dB Max: 100 дБ
- Полоса частот: 0.23 МГц
- Тип выхода: Differential
- CMRR: 97 дБ
- Slew Rate: 30 В/мкс
- Диапазон напряжения питания: 9 В ... 18 В
- Ток потребления: 3.4 мА
- Amplifier Case Style: DIP
- Количество выводов: 8
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: DIP
- Тип усилителя: Operational
- Семейство: 1102
- Gain Bandwidth: 3.5 МГц
- Input Offset Drift Max: 2µV/°C
- Input Offset Voltage Max: 0.15 мВ
- Рабочий диапазон температрур: 0°C ... +70°C
- Тип выхода: Single Ended
- Напряжение питания номинальное: 22 В
- Способ монтажа: Through Hole
Дополнительные аксессуары:
- HARWIN - D2608-42
- Multicomp - 2227MC-08-03-18-F1
- STANNOL - 574601
