Datasheet ACPL-782T-300E - Avago Technologies Даташит PLASTIC AUTOMOTIVE ISOLATION усилитель — Даташит
Наименование модели: ACPL-782T-300E
 Купить ACPL-782T-300E на РадиоЛоцман.Цены — от 159 до 1 778 ₽43 предложений от 19 поставщиков Интегральные микросхемы Аналоговая техника — усилители — инструменты, ОУ (операционные), буферные  | |||
| ACPL-782T-300E | от 159 ₽ | ||
| ACPL-782T-300E Avago Technologies  | 262 ₽ | ||
| ACPL-782T-300E Broadcom  | от 552 ₽ | ||
| ACPL-782T-300E | по запросу | ||
Производитель: Avago Technologies
Описание: PLASTIC AUTOMOTIVE ISOLATION усилитель
ACPL-782T-000E
Automotive Isolation Amplifier
DataSheet
Lead (Pb) Free RoHS 6 fully compliant
RoHS 6 fully compliant options available; -xxxE denotes a lead-free product
Your Electronic Engineering Resource
XRT91L30 STS12-STM4 OR STS3-STM1 SONET-SDH Transceiver
General Description:
The XRT91L30 is a fully integrated SONET/SDH transceiver for SONET/SDH 622.08 Mbps STS-12/STM-4 or 155.52 Mbps STS-3/STM-1 applications.
The transceiver includes an on-chip Clock Multiplier Unit (CMU), which uses a high frequency Phase- Locked Loop (PLL) to generate the high-speed transmit serial clock from a slower external clock reference. It also provides Clock and Data Recovery (CDR) function by synchronizing its on-chip Voltage Controlled Oscillator (VCO) to the incoming serial data stream. The internal CDR unit can be disabled and bypassed in lieu of an externally recovered received clock from the optical module. Either the internally recovered clock or the externally recovered clock can be used for loop timing applications. The chip provides serial-to-parallel and parallel-to-serial converters using an 8-bit wide LVTTL system interface in both receive and transmi
- Количество усилителей: 1
 - Input Offset Voltage: 2 мВ
 - Gain dB Max: 8.16 дБ
 - Полоса частот: 100 кГц
 - Isolation Voltage: 3750Vrms
 - Gain Non-Linearity Max: 0.004%
 - Slew Rate: 10kV/µs
 - Диапазон напряжения питания: 4.5 В ... 5.5 В
 - Ток потребления: 10.86 мА
 - Amplifier Case Style: DIP
 - Количество выводов: 8
 - SVHC: No SVHC (18-Jun-2010)
 - Тип корпуса: DIP
 - Семейство: 782
 - Gain Bandwidth: 100 кГц
 - Рабочий диапазон температрур: -40°C ... +125°C
 - Способ монтажа: Through Hole
ACPL782T300E, ACPL 782T 300E
