Datasheet ACPL-C780-000E - Avago Technologies Даташит ИС, MINIATURE ISOLATION усилитель — Даташит
Наименование модели: ACPL-C780-000E
 Купить ACPL-C780-000E на РадиоЛоцман.Цены — от 129 до 1 072 ₽47 предложений от 18 поставщиков Интегральные микросхемы Аналоговая техника — усилители — инструменты, ОУ (операционные), буферные  | |||
| ACPL-C780-000E Broadcom  | от 606 ₽ | ||
| ACPL-C780-000E | 662 ₽ | ||
| ACPL-C780-000E Broadcom  | 852 ₽ | ||
| ACPL-C780-000E Broadcom  | от 1 072 ₽ | ||
Производитель: Avago Technologies
Описание: ИС, MINIATURE ISOLATION усилитель
ACPL-C78A, ACPL-C780, ACPL-C784
Miniature Isolation Amplifiers
Data Sheet
Description
The ACPL-C78A/C780/C784 isolation amplifier family was designed for current sensing in electronic motor drives.
In a typical implementation, motor currents flow through an external resistor and the resulting analog voltage drop is sensed by the ACPL-C78A/C780/C784. A differential output voltage is created on the other side of the ACPL-C78A/ C780/C784 optical isolation barrier. This differential output voltage is proportional to the motor current and can be converted to a single-ended signal by using an op-amp as shown in the recommended application circuit. Since common-mode voltage swings of several hundred volts in tens of nanoseconds are common in modern switching inverter motor drives, the ACPL-C78A/C780/C784 was designed to ignore very high common-mode transient slew rates (of at least 10 kV/s). The high CMR capability of the ACPL-C78A/C780/C784 isolation amplifier provides the precision and st
- Количество усилителей: 1
 - Input Offset Voltage: 2 мВ
 - Gain dB Max: 8.24 дБ
 - Полоса частот: 100 кГц
 - Isolation Voltage: 5000Vrms
 - Gain Non-Linearity Max: 0.004%
 - Slew Rate: 10kV/µs
 - Диапазон напряжения питания: 4.5 В ... 5.5 В
 - Ток потребления: 11 мА
 - Amplifier Case Style: SOIC
 - Количество выводов: 8
 - SVHC: No SVHC (18-Jun-2010)
 - Тип корпуса: SOIC
 - Семейство: 780
 - Gain Bandwidth: 100 кГц
 - Рабочий диапазон температрур: -40°C ... +100°C
 - Способ монтажа: SMD
ACPLC780000E, ACPL C780 000E
