Datasheet ACPL-C784-000E - Avago Technologies Даташит ИС, MINIATURE ISOLATION усилитель — Даташит
Avago Technologies ACPL-C784-000E
Наименование модели: ACPL-C784-000E
36 предложений от 16 поставщиков
ACPL-C784-000E
Avago Technologies
348 ₽
ACPL-C784-000E
Broadcom
452 ₽
Элитан
ACPL-C784-000E
753 ₽
ACPL-C784-000E
Avago Technologies
Производитель: Avago Technologies
Описание: ИС, MINIATURE ISOLATION усилитель
data sheetСкачать Data Sheet
ACPL-C78A, ACPL-C780, ACPL-C784
Miniature Isolation Amplifiers
Data Sheet
Description
The ACPL-C78A/C780/C784 isolation amplifier family was designed for current sensing in electronic motor drives.
In a typical implementation, motor currents flow through an external resistor and the resulting analog voltage drop is sensed by the ACPL-C78A/C780/C784. A differential output voltage is created on the other side of the ACPL-C78A/ C780/C784 optical isolation barrier. This differential output voltage is proportional to the motor current and can be converted to a single-ended signal by using an op-amp as shown in the recommended application circuit. Since common-mode voltage swings of several hundred volts in tens of nanoseconds are common in modern switching inverter motor drives, the ACPL-C78A/C780/C784 was designed to ignore very high common-mode transient slew rates (of at least 10 kV/s). The high CMR capability of the ACPL-C78A/C780/C784 isolation amplifier provides the precision and st
  • Количество усилителей: 1
  • Input Offset Voltage: 2 мВ
  • Gain dB Max: 8.4 дБ
  • Полоса частот: 100 кГц
  • Isolation Voltage: 5000Vrms
  • Gain Non-Linearity Max: 0.004%
  • Slew Rate: 10kV/µs
  • Диапазон напряжения питания: 4.5 В ... 5.5 В
  • Ток потребления: 11 мА
  • Amplifier Case Style: SOIC
  • Количество выводов: 8
  • SVHC: No SVHC (18-Jun-2010)
  • Тип корпуса: SOIC
  • Семейство: 784
  • Gain Bandwidth: 100 кГц
  • Рабочий диапазон температрур: -40°C ... +100°C
  • Способ монтажа: SMD
ACPLC784000E, ACPL C784 000E
На английском языке: Datasheet ACPL-C784-000E - Avago Technologies IC, MINIATURE ISOLATION AMP
