Datasheet ACPL-C78A-000E - Avago Technologies Даташит ИС, MINIATURE ISOLATION усилитель — Даташит
Наименование модели: ACPL-C78A-000E
Производитель: Avago Technologies
Описание: ИС, MINIATURE ISOLATION усилитель
ACPL-C78A, ACPL-C780, ACPL-C784
Miniature Isolation Amplifiers
Data Sheet
Description
The ACPL-C78A/C780/C784 isolation amplifier family was designed for current sensing in electronic motor drives.
In a typical implementation, motor currents flow through an external resistor and the resulting analog voltage drop is sensed by the ACPL-C78A/C780/C784. A differential output voltage is created on the other side of the ACPL-C78A/ C780/C784 optical isolation barrier. This differential output voltage is proportional to the motor current and can be converted to a single-ended signal by using an op-amp as shown in the recommended application circuit. Since common-mode voltage swings of several hundred volts in tens of nanoseconds are common in modern switching inverter motor drives, the ACPL-C78A/C780/C784 was designed to ignore very high common-mode transient slew rates (of at least 10 kV/s). The high CMR capability of the ACPL-C78A/C780/C784 isolation amplifier provides the precision and st
- Количество усилителей: 1
- Input Offset Voltage: 2 мВ
- Gain dB Max: 8.08 дБ
- Полоса частот: 100 кГц
- Isolation Voltage: 5000Vrms
- Gain Non-Linearity Max: 0.004%
- Slew Rate: 10kV/µs
- Диапазон напряжения питания: 4.5 В ... 5.5 В
- Ток потребления: 11 мА
- Amplifier Case Style: SOIC
- Количество выводов: 8
- SVHC: No SVHC (18-Jun-2010)
- Тип корпуса: SOIC
- Семейство: 78
- Gain Bandwidth: 100 кГц
- Рабочий диапазон температрур: -40°C ... +100°C
- Способ монтажа: SMD
ACPLC78A000E, ACPL C78A 000E
