Datasheet Texas Instruments ISO721DG4 — Даташит
СерияISO721
МодельISO721DG4
2,5 кВ (среднеквадратичное значение), 100 Мбит/с, 1-канальный цифровой изолятор 8-SOIC от -40 до 125
ISO72x Single Channel High-Speed Digital Isolators datasheet
PDF, 2.6 Мб, Версия: L, Файл опубликован: 19 окт 2015
Package TypeD
Package QTY75
МаркировкаISO721
Width (мм)3.91
Length (мм)4.9
Thickness (мм)1.58
Max Height (мм)1.75
Data Rate(Max)100 Mbps
Default OutputHigh
Forward/Reverse Channels1/0
Integrated Isolated PowerNo
Isolation Rating2500 Vrms
Количество каналов1
Время задержки распространения17 нс
Propagation Delay(Typ)17 нс
Surge Voltage Rating4000 Vpk
VCC(Max)5 В
VCC(Min)3.3 В
  • Evaluation Modules & Boards: ISO72XEVM
    ISO72x Evaluation Module
  • The ISO72x Family of High-Speed Digital Isolators
    PDF, 385 Кб, Файл опубликован: 11 янв 2006
    This application report provides an overview of the need for, implementations of, and characteristics of electrical isolation in high-speed digital circuits. It discusses the advantages and disadvantages of optical, magnetic (inductive), and electrical (capacitive) signal transmissions across an isolation barrier with particular focus on the capacitor-coupled technique used in the ISO72x family of
  • ISO72X Digital Isolator Magnetic-Field Immunity (Rev. A)
    PDF, 651 Кб, Версия: A, Файл опубликован: 22 фев 2006
    The purpose of this analysis is to estimate the immunity of the ISO72x family of digital isolators to magnetic fields.
  • High-Voltage Lifetime of the ISO72x Family of Digital Isolators
    PDF, 218 Кб, Файл опубликован: 17 янв 2006
    This application report examines the high-voltage lifetime characteristics of the isolation barrier in the ISO72x family of digital isolators. This provides the user with information regarding the long-term, high-voltage withstand capability of this family of products.
  • Isolated RS-485 Reference Design
    PDF, 80 Кб, Файл опубликован: 28 окт 2009
    This design note presents the reference designs of isolated RS-485 nodes, using bus voltages of 3.3 V and 5 V. Various transceivers are used to satisfy the requirements for low, medium, and high data rates, as well as to accommodate the need for half- and full-duplex operation.
  • Digital Isolator Design Guide (Rev. A)
    PDF, 487 Кб, Версия: A, Файл опубликован: 4 ноя 2014
  • Semiconductors > Isolation > Digital Isolators
На английском языке: Datasheet Texas Instruments ISO721DG4
