Datasheet ADA4858-3ACPZ-R2 - Analog Devices Даташит ИС, OP-AMP, 600 МГц, 600 В/мкс, LFCSP-16 — Даташит
Наименование модели: ADA4858-3ACPZ-R2
Микросхема Операционный усилитель, ANALOG DEVICES ADA4858-3ACPZ-R2 Operational Amplifier, Triple, 3 Amplifier, 600MHz, 600V/µs, 3V to 5.5V, LFCSP, 16Pins
ADA4858-3ACPZ-R2
367 ₽
ADA4858-3ACPZ-R2
388 ₽
Зенер
Россия и страны ТС
ADA4858-3ACPZ-R2
702 ₽
ADA4858-3ACPZ-R2
Производитель: Analog Devices
Описание: ИС, OP-AMP, 600 МГц, 600 В/мкс, LFCSP-16
data sheetСкачать Data Sheet
Single-Supply, High Speed, Triple Op Amp with Charge Pump ADA4858-3
FEATURES
Integrated charge pump Supply range: 3 V to 5.5 V Output range: -3.3 V to -1.8 V 50 mA maximum output current for external use at -3 V High speed amplifiers -3 dB bandwidth: 600 MHz Slew rate: 600 V/s 0.1 dB flatness: 85 MHz 0.1% settling time: 18 ns Low power Total quiescent current: 42 mA Power-down feature High input common-mode voltage range -1.8 V to +3.8 V at +5 V supply Current feedback architecture Differential gain error: 0.01% Differential phase error: 0.02° Available in 16-lead LFCSP
CONNECTION DIAGRAM
ADA4858-3
ADA48583ACPZR2, ADA4858 3ACPZ R2
На английском языке: Datasheet ADA4858-3ACPZ-R2 - Analog Devices IC, OP-AMP, 600 MHz, 600 V/µs, LFCSP-16
