Datasheet LT1013DN8 - Linear Technology Даташит OP усилитель, DUAL PRECISION, 1013, DIP8 — Даташит
Наименование модели: LT1013DN8
![]() 46 предложений от 21 поставщиков Микросхема Операционный усилитель, LINEAR TECHNOLOGY LT1013DN8#PBF Operational Amplifier, Dual, 2 Amplifier, 800kHz, 0.4V/µs, 4V to 44V, DIP, 8Pins | |||
LT1013DN8#PBF Analog Devices | от 70 ₽ | ||
LT1013DN8 Analog Devices | 498 ₽ | ||
LT1013DN8#PBF Analog Devices | от 537 ₽ | ||
LT1013DN8#PBF | по запросу |
Производитель: Linear Technology
Описание: OP усилитель, DUAL PRECISION, 1013, DIP8
FEATURES
s
LT1013/LT1014 Quad Precision Op Amp (LT1014) Dual Precision Op Amp (LT1013) DESCRIPTIO
The LT ®1014 is the first precision quad operational amplifier which directly upgrades designs in the industry standard 14-pin DIP LM324/LM348/OP-11/4156 pin configuration.
It is no longer necessary to compromise specifications, while saving board space and cost, as compared to single operational amplifiers. The LT1014's low offset voltage of 50µV, drift of 0.3µV/°C, offset current of 0.15nA, gain of 8 million, common mode rejection of 117dB and power supply rejection of 120dB qualify it as four truly precision operational amplifiers. Particularly important is the low offset voltage, since no offset null terminals are provided in the quad configuration. Although supply current is only 350µA per amplifier, a new output stage design sources and sinks in excess of 20mA of load current, while retaining high voltage gain. Similarly, the LT1013 is the first precision dual op amp in the 8-pin in
- Количество усилителей: 2
- Количество выводов: 8
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: DIP
- Тип усилителя: Precision
- Семейство: 1013
- IC Generic Number: 1013
- Рабочий диапазон температрур: Commercial
- Напряжение смещения входа максимальное: 800 мкВ
- Количество логических функций: 1013
- Особенности ОУ: Op-Amp, Dual Precision
- Скорость нарастания: 0.4 В/мкс
- Ток потребления: 0.35 мА
- Ток потребления максимальный: 0.55 мА
- Напряжение питания (+) номинальное: 15 В
Дополнительные аксессуары:
- Dow Corning - 2265931
- Fischer Elektronik - ICK SMD A 8 SA
- Fischer Elektronik - WLK 5
