Datasheet LT1014DN - Linear Technology Даташит OP усилитель, QUAD PRECISION, 1014, DIP14 — Даташит
Linear Technology LT1014DN
Наименование модели: LT1014DN
50 предложений от 23 поставщиков
Микросхема Операционный усилитель, LINEAR TECHNOLOGY LT1014DN#PBF Operational Amplifier, Quad, 4 Amplifier, 800kHz, 0.4V/µs, 4V to 44V, DIP, 14Pins
LT1014DN
541 ₽
LT1014DN#PBF
от 888 ₽
LT1014DN
от 1 388 ₽
SUV System
LT1014DN#PBF
Производитель: Linear Technology
Описание: OP усилитель, QUAD PRECISION, 1014, DIP14
data sheetСкачать Data Sheet
FEATURES
s
LT1013/LT1014 Quad Precision Op Amp (LT1014) Dual Precision Op Amp (LT1013) DESCRIPTIO
The LT ®1014 is the first precision quad operational amplifier which directly upgrades designs in the industry standard 14-pin DIP LM324/LM348/OP-11/4156 pin configuration.
It is no longer necessary to compromise specifications, while saving board space and cost, as compared to single operational amplifiers. The LT1014's low offset voltage of 50µV, drift of 0.3µV/°C, offset current of 0.15nA, gain of 8 million, common mode rejection of 117dB and power supply rejection of 120dB qualify it as four truly precision operational amplifiers. Particularly important is the low offset voltage, since no offset null terminals are provided in the quad configuration. Although supply current is only 350µA per amplifier, a new output stage design sources and sinks in excess of 20mA of load current, while retaining high voltage gain. Similarly, the LT1013 is the first precision dual op amp in the 8-pin in
  • Тип ОУ: Precision
  • Количество усилителей: 4
  • Slew Rate: 0.4 В/мкс
  • Диапазон напряжения питания: ± 2 В ... ± 18 В
  • Amplifier Case Style: DIP
  • Количество выводов: 14
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: DIP
  • Тип усилителя: Precision
  • Семейство: 1014
  • IC Generic Number: 1014
  • Рабочий диапазон температрур: Commercial
  • Input Offset Voltage Max: 800 мкВ
  • Количество логических функций: 1014
  • Особенности ОУ: Quad
  • Ток потребления: 0.35 мА
  • Supply Current Max: 0.55 мА
  • Напряжение питания номинальное: 15 В
Дополнительные аксессуары:
  • Dow Corning - 2265931
  • Fischer Elektronik - ICK 14/16 B
  • Fischer Elektronik - ICK 14/16 L
  • Fischer Elektronik - WLK 5
На английском языке: Datasheet LT1014DN - Linear Technology OP AMP, QUAD PRECISION, 1014, DIP14
