Datasheet LT1078S8 - Linear Technology Даташит OP усилитель, DUAL PRECISION, SMD, 1078 — Даташит
Linear Technology LT1078S8
Наименование модели: LT1078S8
45 предложений от 23 поставщиков
Микросхема Операционный усилитель, LINEAR TECHNOLOGY LT1078S8#PBF Operational Amplifier, Dual, 2 Amplifier, 200kHz, 0.1V/µs, 2.3V to 12V, SOIC, 8Pins
LT1078S8#PBF
86 ₽
727GS
LT1078S8#TRPBF
от 188 ₽
LT1078S8#PBF
от 357 ₽
LT1078S8#PBF
Производитель: Linear Technology
Описание: OP усилитель, DUAL PRECISION, SMD, 1078
data sheetСкачать Data Sheet
FEATURES
s s s s s s s s s s s
LT1078/LT1079 Micropower, Dual and Quad, Single Supply, Precision Op Amps DESCRIPTIO
The LT ® 1078 is a micropower dual op amp in 8-pin packages including the small outline surface mount package.
The LT1079 is a micropower quad op amp offered in the standard 14-pin packages. Both devices are optimized for single supply operation at 5V. ±15V specifications are also provided. Micropower performance of competing devices is achieved at the expense of seriously degrading precision, noise, speed and output drive specifications. The design effort of the LT1078/LT1079 was concentrated on reducing supply current without sacrificing other parameters. The offset voltage achieved is the lowest on any dual or quad nonchopper stabilized op amp--micropower or otherwise. Offset current, voltage and current noise, slew rate and gain bandwidth product are all two to ten times better than on previous micropower op amps. The 1/f corner of the voltage noise spectrum is at 0.
  • Тип ОУ: Precision
  • Количество усилителей: 2
  • Полоса частот: 0.2 МГц
  • Slew Rate: 0.1 В/мкс
  • Диапазон напряжения питания: 2.3 В ... 12 В
  • Amplifier Case Style: SOIC
  • Количество выводов: 8
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: SOIC
  • Тип усилителя: Precision
  • Семейство: 1078
  • Gain Bandwidth: 200 кГц
  • IC Generic Number: 1078
  • Рабочий диапазон температрур: Commercial
  • Input Offset Voltage Max: 0.18 мВ
  • Количество логических функций: 1078
  • Напряжение питания номинальное: 5 В
  • Способ монтажа: SMD
Дополнительные аксессуары:
  • Dow Corning - 2265931
  • Fischer Elektronik - ICK SMD A 5 SA
  • Fischer Elektronik - WLK 5
  • Roth Elektronik - RE932-01
На английском языке: Datasheet LT1078S8 - Linear Technology OP AMP, DUAL PRECISION, SMD, 1078
