Datasheet LT1218LCS8 - Linear Technology Даташит ИС, OP усилитель, PRECI, RR I/O, 8SOIC — Даташит
Linear Technology LT1218LCS8
Наименование модели: LT1218LCS8
30 предложений от 19 поставщиков
, Operational Amplifier, 1 Func, 250uV Offset-Max, BIPolar, PDSO8
LT1218LCS8#TRPBF
243 ₽
727GS
LT1218LCS8#PBF
от 273 ₽
LT1218LCS8#PBF
от 306 ₽
Элитан
LT1218LCS8
1 067 ₽
Производитель: Linear Technology
Описание: ИС, OP усилитель, PRECI, RR I/O, 8SOIC
data sheetСкачать Data Sheet
LT1218/LT1219 Precision Rail-to-Rail Input and Output Op Amps
FEATURES
s s s s s s
DESCRIPTION
The LT ®1218/LT1219 are bipolar op amps which combine rail-to-rail input and output operation with precision specifications.
Unlike other rail-to-rail amplifiers, the LT1218/ LT1219's input offset voltage is a low 90µV across the entire rail-to-rail input range, not just a portion of it. Using a patented technique, both input stages of the LT1218/ LT1219 are trimmed: one at the negative supply and the other at the positive supply. The resulting common mode rejection of 97dB minimum is much better than other railto-rail input op amps. A minimum open-loop gain of 500V/mV into a 10k load virtually eliminates all gain error. The LT1218 has conventional compensation which assures stability for capacitive loads of 1000pF or less. The LT1219 has compensation that requires the use of a 0.1µF output capacitor, which improves the amplifier's supply rejection and reduces output impedance at high frequ
Данные для моделированияДанные для моделирования
  • Тип ОУ: Precision
  • Количество усилителей: 1
  • Полоса частот: 300 кГц
  • Slew Rate: 0.1 В/мкс
  • Диапазон напряжения питания: 2 В ... ± 5 В
  • Amplifier Case Style: SOIC
  • Количество выводов: 8
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: SOIC
  • Семейство: 1218
  • Gain Bandwidth: 300 кГц
  • Рабочий диапазон температрур: 0°C ... +70°C
  • Способ монтажа: SMD
На английском языке: Datasheet LT1218LCS8 - Linear Technology IC, OP AMP, PRECI, RR I/O, 8SOIC
