Datasheet LT1228CN8 - Linear Technology Даташит усилитель, CURRENT FEEDBACK, 1228, DIP8 — Даташит
Наименование модели: LT1228CN8
![]() 44 предложений от 20 поставщиков Интегральные микросхемы Аналоговая техника — усилители — инструменты, ОУ (операционные), буферные | |||
LT1228CN8 Linear Technology | 314 ₽ | ||
LT1228CN8#PBF Analog Devices | от 1 238 ₽ | ||
LT1228CN8#PBF Linear Technology | по запросу | ||
LT1228CN8 | по запросу |
Производитель: Linear Technology
Описание: Усилитель, CURRENT FEEDBACK, 1228, DIP8
LT1228 100MHz Current Feedback Amplifier with DC Gain Control DESCRIPTIO
The LT®1228 makes it easy to electronically control the gain of signals from DC to video frequencies.
The LT1228 implements gain control with a transconductance amplifier (voltage to current) whose gain is proportional to an externally controlled current. A resistor is typically used to convert the output current to a voltage, which is then amplified with a current feedback amplifier. The LT1228 combines both amplifiers into an 8-pin package, and operates on any supply voltage from 4V (±2V) to 30V (±15V). A complete differential input, gain controlled amplifier can be implemented with the LT1228 and just a few resistors. The LT1228 transconductance amplifier has a high impedance differential input and a current source output with wide output voltage compliance. The transconductance, gm, is set by the current that flows into Pin 5, ISET. The small signal gm is equal to ten times the value of ISET and this relations
- Тип ОУ: Current Feedback
- Количество усилителей: 1
- Полоса частот: 100 МГц
- Slew Rate: 3500 В/мкс
- Диапазон напряжения питания: 2 В ... 15 В
- Amplifier Case Style: DIP
- Количество выводов: 8
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: DIP
- Тип усилителя: Video
- Семейство: 1228
- Тактовая частота: 75 МГц
- Gain Bandwidth: 75 МГц
- Gain dB Max: 65 дБ
- IC Generic Number: 1228
- Рабочий диапазон температрур: Commercial
- Input Offset Drift Max: 10µV/°C
- Input Offset Voltage Max: 10 мВ
- Количество логических функций: 1228
- Особенности ОУ: Current Feedback Amplifier
- Settling Time: 45 нс
- Ток потребления: 7 мА
- Напряжение питания номинальное: 18 В
- Supply Voltage - Nom: 18 В
- Способ монтажа: Through Hole
- Common Mode Voltage VCM: 13.5 В
Дополнительные аксессуары:
- Dow Corning - 2265931
- Fischer Elektronik - ICK SMD A 8 SA
- Fischer Elektronik - WLK 5
- Multicomp - 2227MC-08-03-18-F1
