Datasheet LT1228CS8 - Linear Technology Даташит усилитель, CURRENT FEEDBACK, 1228, SOIC8 — Даташит
Linear Technology LT1228CS8
Наименование модели: LT1228CS8
35 предложений от 21 поставщиков
Микросхема Операционный усилитель, LINEAR TECHNOLOGY LT1228CS8#PBF Transconductance Amplifier, Video, 1 Amplifier, 15V, 75MHz, -13.5V, 13.5V, SOIC
727GS
LT1228CS8#TRPBF
от 273 ₽
Элитан
LT1228CS8
980 ₽
Эиком
LT1228CS8#PBF
от 1 348 ₽
LT1228CS8#TR
Производитель: Linear Technology
Описание: Усилитель, CURRENT FEEDBACK, 1228, SOIC8
data sheetСкачать Data Sheet
LT1228 100MHz Current Feedback Amplifier with DC Gain Control DESCRIPTIO
The LT®1228 makes it easy to electronically control the gain of signals from DC to video frequencies.
The LT1228 implements gain control with a transconductance amplifier (voltage to current) whose gain is proportional to an externally controlled current. A resistor is typically used to convert the output current to a voltage, which is then amplified with a current feedback amplifier. The LT1228 combines both amplifiers into an 8-pin package, and operates on any supply voltage from 4V (±2V) to 30V (±15V). A complete differential input, gain controlled amplifier can be implemented with the LT1228 and just a few resistors. The LT1228 transconductance amplifier has a high impedance differential input and a current source output with wide output voltage compliance. The transconductance, gm, is set by the current that flows into Pin 5, ISET. The small signal gm is equal to ten times the value of ISET and this relations
  • Тип ОУ: Current Feedback
  • Количество усилителей: 1
  • Полоса частот: 100 МГц
  • Slew Rate: 500 В/мкс
  • Диапазон напряжения питания: ± 2 В ... ± 15 В
  • Amplifier Case Style: SOIC
  • Количество выводов: 8
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: SOIC
  • Тип усилителя: Video
  • Семейство: 1228
  • Тактовая частота: 75 МГц
  • Gain Bandwidth: 75 МГц
  • Gain dB Max: 65 дБ
  • IC Generic Number: 1228
  • Рабочий диапазон температрур: Commercial
  • Input Offset Drift Max: 10µV/°C
  • Input Offset Voltage Max: 10 мВ
  • Количество логических функций: 1228
  • Особенности ОУ: Current Feedback Amplifier
  • Settling Time: 45 нс
  • Ток потребления: 7 мА
  • Напряжение питания номинальное: 18 В
  • Supply Voltage - Nom: 18 В
  • Способ монтажа: SMD
  • Common Mode Voltage VCM: 13.5 В
Дополнительные аксессуары:
  • Dow Corning - 2265931
  • Fischer Elektronik - ICK SMD A 5 SA
  • Fischer Elektronik - WLK 5
  • Roth Elektronik - RE932-01
На английском языке: Datasheet LT1228CS8 - Linear Technology AMP, CURRENT FEEDBACK, 1228, SOIC8
