Datasheet LT1352CS8 - Linear Technology Даташит OP усилитель, HS, DUAL, 250UA, 3 МГц, 8SOIC — Даташит
Наименование модели: LT1352CS8
![]() 47 предложений от 24 поставщиков LINEAR TECHNOLOGY LT1352CS8#PBF Operational Amplifier, Dual, 2 Amplifier, 3MHz, 200V/µs, 5V to 36V, SOIC, 8Pins | |||
LT1352CS8#PBF Analog Devices | 277 ₽ | ||
LT1352CS8#TR Linear Technology | 334 ₽ | ||
LT1352CS8#TR Linear Technology | 360 ₽ | ||
LT1352CS8#PBF Analog Devices | от 1 279 ₽ |
Производитель: Linear Technology
Описание: OP усилитель, HS, DUAL, 250UA, 3 МГц, 8SOIC
LT1352/LT1353 Dual and Quad 250µA, 3MHz, 200V/µs Operational Amplifiers DESCRIPTIO
The LT ®1352/LT1353 are dual and quad, very low power, high speed operational amplifiers with outstanding AC and DC performance.
The amplifiers feature much lower supply current and higher slew rate than devices with comparable bandwidth. The circuit combines the slewing performance of a current feedback amplifier in a true operational amplifier with matched high impedance inputs. The high slew rate ensures that the large-signal bandwidth is not degraded. Each output is capable of driving a 1k load to ±13V with ±15V supplies and a 500 load to ±3.4V on ±5V supplies. The LT1352/LT1353 are members of a family of fast, high performance amplifiers using this unique topology and employing Linear Technology Corporation's advanced complementary bipolar processing. For higher bandwidth devices with higher supply current see the LT1354 through LT1365 data sheets. Bandwidths of 12MHz, 25MHz, 50MHz and 70MHz are ava
- Тип ОУ: Low Power
- Количество усилителей: 2
- Полоса частот: 3 МГц
- Slew Rate: 200 В/мкс
- Диапазон напряжения питания: ± 2.5 В ... ± 15 В
- Amplifier Case Style: SOIC
- Количество выводов: 8
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: SOIC
- Семейство: 1352
- Gain Bandwidth: 3 МГц
- Рабочий диапазон температрур: 0°C ... +70°C
- Способ монтажа: SMD
