Datasheet LT1354CS8 - Linear Technology Даташит ИС, SM, OP усилитель, 400V/µSEC — Даташит
Наименование модели: LT1354CS8
![]() 40 предложений от 22 поставщиков LINEAR TECHNOLOGY LT1354CS8#PBF Operational Amplifier, Single, 1 Amplifier, 12MHz, 400V/µs, ± 2.5V to ± 15V, SOIC, 8Pins | |||
LT1354CS8#PBF Linear Technology | 246 ₽ | ||
LT1354CS8#TRPBF Linear Technology | от 279 ₽ | ||
LT1354CS8#PBF Analog Devices | от 820 ₽ | ||
LT1354CS8#PBF Linear Technology | по запросу |
Производитель: Linear Technology
Описание: ИС, SM, OP усилитель, 400V/µSEC
LT1354 12MHz, 400V/µs Op Amp
FEATURES
s s s s s s s s s s s s s s s
DESCRIPTION
The LT ®1354 is a low power, high speed, high slew rate operational amplifier with outstanding AC and DC performance.
The LT1354 has much lower supply current, lower input offset voltage, lower input bias current, and higher DC gain than devices with comparable bandwidth. The circuit topology is a voltage feedback amplifier with the slewing characteristics of a current feedback amplifier. The amplifier is a single gain stage with outstanding settling characteristics which makes the circuit an ideal choice for data acquisition systems. The output drives a 500 load to ±12V with ±15V supplies and a 150 load to ±2.5V on ±5V supplies. The amplifier is also stable with any capacitive load which makes it useful in buffer or cable driver applications. The LT1354 is a member of a family of fast, high performance amplifiers using this unique topology and employing Linear Technology Corporation's advanced bipolar com
- Тип ОУ: Low Power
- Количество усилителей: 1
- Полоса частот: 12 МГц
- Slew Rate: 400 В/мкс
- Диапазон напряжения питания: ± 2.5 В ... ± 15 В
- Amplifier Case Style: SOIC
- Количество выводов: 8
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: SOIC
- Тип усилителя: Operational
- Семейство: 1354
- Gain Bandwidth: 5.5 МГц
- Input Offset Voltage Max: 0.8 мВ
- Рабочий диапазон температрур: -40°C ... +85°C
- Напряжение питания номинальное: 18 В
- Способ монтажа: SMD
Дополнительные аксессуары:
- Fischer Elektronik - ICK SMD A 10 SA
- Roth Elektronik - RE932-01
- STANNOL - 631954
