Datasheet LT1357CN8 - Linear Technology Даташит ИС, OP усилитель, 25 МГц, 1357, DIP8 — Даташит
Наименование модели: LT1357CN8
![]() 42 предложений от 18 поставщиков Интегральные микросхемы Аналоговая техника — усилители — инструменты, ОУ (операционные), буферные | |||
LT1357CN8#PBF Analog Devices | 165 ₽ | ||
LT1357CN8#PBF Linear Technology | от 332 ₽ | ||
LT1357CN8#PBF Analog Devices | 612 ₽ | ||
LT1357CN8 Analog Devices | по запросу |
Производитель: Linear Technology
Описание: ИС, OP усилитель, 25 МГц, 1357, DIP8
LT1357 25MHz, 600V/µs Op Amp
FEATURES
s s s s s s s s s s s s s s s
DESCRIPTION
The LT ®1357 is a high speed, very high slew rate operational amplifier with outstanding AC and DC performance.
The LT1357 has much lower supply current, lower input offset voltage, lower input bias current, and higher DC gain than devices with comparable bandwidth. The circuit topology is a voltage feedback amplifier with the slewing characteristics of a current feedback amplifier. The amplifier is a single gain stage with outstanding settling characteristics which makes the circuit an ideal choice for data acquisition systems. The output drives a 500 load to ±12V with ±15V supplies and a 150 load to ±2.5V on ±5V supplies. The amplifier is also stable with any capacitive load which makes it useful in buffer or cable driver applications. The LT1357 is a member of a family of fast, high performance amplifiers using this unique topology and employing Linear Technology Corporation's advanced bipolar compleme
- Тип ОУ: High Speed
- Количество усилителей: 1
- Полоса частот: 25 МГц
- Slew Rate: 600 В/мкс
- Диапазон напряжения питания: ± 2.5 В ... ± 15 В
- Amplifier Case Style: DIP
- Количество выводов: 8
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: DIP
- Тип усилителя: Operational
- Семейство: 1357
- Gain Bandwidth: 22 МГц
- IC Generic Number: 1357
- Рабочий диапазон температрур: Commercial
- Input Offset Voltage Max: 1 мВ
- Количество логических функций: 1357
- Особенности ОУ: High Speed
- Напряжение питания номинальное: 15 В
- Способ монтажа: Through Hole
Дополнительные аксессуары:
- Dow Corning - 2265931
- Fischer Elektronik - ICK SMD A 8 SA
- Fischer Elektronik - WLK 5
- Multicomp - 2227MC-08-03-18-F1
