Datasheet LT1357CS8 - Linear Technology Даташит ИС, OP усилитель, 25 МГц, SMD, 1357, SOIC8 — Даташит
Наименование модели: LT1357CS8
Купить LT1357CS8 на РадиоЛоцман.Цены — от 211 до 2 706 ₽ 32 предложений от 21 поставщиков LINEAR TECHNOLOGY LT1357CS8#PBF Operational Amplifier, Single, 1 Amplifier, 25MHz, 600V/µs, ± 2.5V to ± 15V, SOIC, 8Pins | |||
LT1357CS8#PBF Analog Devices | 211 ₽ | ||
LT1357CS8#TR Linear Technology | 256 ₽ | ||
LT1357CS8#TR Linear Technology | 260 ₽ | ||
LT1357CS8#PBF Linear Technology | 307 ₽ |
Производитель: Linear Technology
Описание: ИС, OP усилитель, 25 МГц, SMD, 1357, SOIC8
LT1357 25MHz, 600V/µs Op Amp
FEATURES
s s s s s s s s s s s s s s s
DESCRIPTION
The LT ®1357 is a high speed, very high slew rate operational amplifier with outstanding AC and DC performance.
The LT1357 has much lower supply current, lower input offset voltage, lower input bias current, and higher DC gain than devices with comparable bandwidth. The circuit topology is a voltage feedback amplifier with the slewing characteristics of a current feedback amplifier. The amplifier is a single gain stage with outstanding settling characteristics which makes the circuit an ideal choice for data acquisition systems. The output drives a 500 load to ±12V with ±15V supplies and a 150 load to ±2.5V on ±5V supplies. The amplifier is also stable with any capacitive load which makes it useful in buffer or cable driver applications. The LT1357 is a member of a family of fast, high performance amplifiers using this unique topology and employing Linear Technology Corporation's advanced bipolar compleme
- Тип ОУ: High Speed
- Количество усилителей: 1
- Полоса частот: 25 МГц
- Slew Rate: 600 В/мкс
- Диапазон напряжения питания: ± 2.5 В ... ± 15 В
- Amplifier Case Style: SOIC
- Количество выводов: 8
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: SOIC
- Тип усилителя: Operational
- Семейство: 1357
- Gain Bandwidth: 22 МГц
- IC Generic Number: 1357
- Рабочий диапазон температрур: Commercial
- Input Offset Voltage Max: 0.8 мВ
- Количество логических функций: 1357
- Напряжение питания номинальное: 15 В
- Способ монтажа: SMD
Дополнительные аксессуары:
- Dow Corning - 2265931
- Fischer Elektronik - ICK SMD A 5 SA
- Fischer Elektronik - WLK 5
- Roth Elektronik - RE932-01
