Datasheet LT1366CN8 - Linear Technology Даташит ИС, OP усилитель, DUAL RRI/O, 1366, DIP8 — Даташит
Linear Technology LT1366CN8
Наименование модели: LT1366CN8
43 предложений от 21 поставщиков
Микросхема Операционный усилитель, LINEAR TECHNOLOGY LT1366CN8#PBF Operational Amplifier, Dual, 2 Amplifier, 400kHz, 0.13V/µs, 1.8V to ± 15V, DIP, 8Pins
LT1366CN8#PBF
524 ₽
Зенер
Россия и страны ТС
LT1366CN8#PBF
от 536 ₽
LT1366CN8#PBF
1 163 ₽
МосЧип
LT1366CN8#PBF
Производитель: Linear Technology
Описание: ИС, OP усилитель, DUAL RRI/O, 1366, DIP8
data sheetСкачать Data Sheet
LT1366/LT1367 LT1368/LT1369 Dual and Quad Precision Rail-to-Rail Input and Output Op Amps
FEATURES
s s s s s s s s s s s s
DESCRIPTION
The LT ®1366/LT1367/LT1368/LT1369 are dual and quad bipolar op amps which combine rail-to-rail input and output operation with precision specifications.
These op amps maintain their characteristics over a supply range of 1.8V to 36V. Operation is specified for 3V, 5V and ±15V supplies. Input offset voltage is typically 150µV, with an open-loop gain AVOL of 1 million while driving a 10k load. Common mode rejection is typically 90dB over the full railto-rail input range, and supply rejection is 110dB. The LT1366/LT1367 have conventional compensation which assures stability for capacitive loads of 1000pF or less. The LT1368/LT1369 have compensation that requires a 0.1µF output capacitor, which improves the amplifier's supply rejection and reduces output impedance at high frequencies. The output capacitor's filtering action reduces high frequency noise, w
  • Тип ОУ: Precision
  • Количество усилителей: 2
  • Полоса частот: 0.4 МГц
  • Slew Rate: 0.13 В/мкс
  • Диапазон напряжения питания: 1.8 В ... ± 15 В
  • Amplifier Case Style: DIP
  • Количество выводов: 8
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: DIP
  • Тип усилителя: Rail - Rail Input / Output (RRIO)
  • Семейство: 1366
  • Gain Bandwidth: 0.4 МГц
  • Вход / выход: Rail-Rail I/O
  • IC Generic Number: 1366
  • Рабочий диапазон температрур: Commercial
  • Input Offset Voltage Max: 0.575 мВ
  • Количество логических функций: 1366
  • Особенности ОУ: RAIL TO RAIL INPUT AND OUTPUT
  • Напряжение питания номинальное: 5 В
Дополнительные аксессуары:
  • Dow Corning - 2265931
  • Fischer Elektronik - ICK SMD A 8 SA
  • Fischer Elektronik - WLK 5
На английском языке: Datasheet LT1366CN8 - Linear Technology IC, OP AMP, DUAL RRI/O, 1366, DIP8
