Datasheet LT1368CS8 - Linear Technology Даташит Operational Amplifier (Op-Amp) ИС — Даташит
Linear Technology LT1368CS8
Наименование модели: LT1368CS8
43 предложений от 24 поставщиков
Микросхема Операционный усилитель, LINEAR TECHNOLOGY LT1368CS8#PBF Operational Amplifier, Dual, 2 Amplifier, 160kHz, 0.065V/µs, ± 5V to ± 15V, SOIC, 8Pins
LT1368CS8#PBF
13 ₽
Зенер
Россия и страны ТС
LT1368CS8
от 354 ₽
МосЧип
LT1368CS8#TRPBF
LifeElectronics
LT1368CS8#PBF
Производитель: Linear Technology
Описание: Operational Amplifier (Op-Amp) ИС
data sheetСкачать Data Sheet
LT1366/LT1367 LT1368/LT1369 Dual and Quad Precision Rail-to-Rail Input and Output Op Amps
FEATURES
s s s s s s s s s s s s
DESCRIPTION
The LT ®1366/LT1367/LT1368/LT1369 are dual and quad bipolar op amps which combine rail-to-rail input and output operation with precision specifications.
These op amps maintain their characteristics over a supply range of 1.8V to 36V. Operation is specified for 3V, 5V and ±15V supplies. Input offset voltage is typically 150µV, with an open-loop gain AVOL of 1 million while driving a 10k load. Common mode rejection is typically 90dB over the full railto-rail input range, and supply rejection is 110dB. The LT1366/LT1367 have conventional compensation which assures stability for capacitive loads of 1000pF or less. The LT1368/LT1369 have compensation that requires a 0.1µF output capacitor, which improves the amplifier's supply rejection and reduces output impedance at high frequencies. The output capacitor's filtering action reduces high frequency noise, w
  • Тип ОУ: Precision
  • Количество усилителей: 2
  • Полоса частот: 160 кГц
  • Slew Rate: 0.065 В/мкс
  • Диапазон напряжения питания: ± 5 В ... ± 15 В
  • Amplifier Case Style: SOIC
  • Количество выводов: 8
На английском языке: Datasheet LT1368CS8 - Linear Technology Operational Amplifier (Op-Amp) IC
