Datasheet LT1632CS8 - Linear Technology Даташит ИС, операционный усилитель, 45 МГц, 45 В/мкс, SOIC-8 — Даташит
Linear Technology LT1632CS8
Наименование модели: LT1632CS8
39 предложений от 20 поставщиков
LINEAR TECHNOLOGY LT1632CS8#PBF Operational Amplifier, Dual, 2 Amplifier, 45MHz, 45V/µs, 2.7V to ± 15V, SOIC, 8Pins
LT1632CS8#TR
268 ₽
Элитан
LT1632CS8
1 127 ₽
Зенер
Россия и страны ТС
LT1632CS8
от 1 390 ₽
LT1632CS8
Производитель: Linear Technology
Описание: ИС, операционный усилитель, 45 МГц, 45 В/мкс, SOIC-8
data sheetСкачать Data Sheet
LT1632/LT1633 45MHz, 45V/µs, Dual/Quad Rail-to-Rail Input and Output Precision Op Amps
FEATURES
s s s s s s s s s s s s s s
DESCRIPTION
The LT ®1632/LT1633 are dual/quad, rail-to-rail input and output op amps with a 45MHz gain-bandwidth product and a 45V/µs slew rate.
The LT1632/LT1633 have excellent DC precision over the full range of operation. Input offset voltage is typically less than 400µV and the minimum open-loop gain of 0.8 million into a 10k load virtually eliminates all gain error. Common mode rejection is typically 83dB over the full railto-rail input range when on a single 5V supply for excellent noninverting performance. The LT1632/LT1633 maintain their performance for supplies from 2.7V to 36V and are specified at 3V, 5V and ±15V supplies. The inputs can be driven beyond the supplies without damage or phase reversal of the output. The output delivers load currents in excess of 35mA. The LT1632 is available in 8-pin PDIP and SO packages with the standard dual op amp pin
  • Тип ОУ: Precision
  • Количество усилителей: 2
  • Полоса частот: 45 МГц
  • Slew Rate: 45 В/мкс
  • Диапазон напряжения питания: 2.7 В ... ± 15 В
  • Amplifier Case Style: SOIC
  • Количество выводов: 8
На английском языке: Datasheet LT1632CS8 - Linear Technology IC, OP-AMP, 45 MHz, 45 V/µs, SOIC-8
