Datasheet LT1639CS - Linear Technology Даташит ИС, SM, OP усилитель, QUAD — Даташит
Linear Technology LT1639CS
Наименование модели: LT1639CS
38 предложений от 20 поставщиков
Микросхема Операционный усилитель, LINEAR TECHNOLOGY LT1639CS#PBF Operational Amplifier, Quad, 4 Amplifier, 1.2MHz, 0.38V/µs, ± 1.5V to ± 22V, SOIC, 14Pins
727GS
LT1639CS#TRPBF
от 161 ₽
LT1639CS#PBF
235 ₽
SUV System
LT1639CS#PBF
LifeElectronics
LT1639CS-TR
Производитель: Linear Technology
Описание: ИС, SM, OP усилитель, QUAD
data sheetСкачать Data Sheet
FEATURES
LT1638/LT1639 1.2MHz, 0.4V/µs Over-The-Top Micropower Rail-to-Rail Input and Output Op Amps DESCRIPTIO
The LT ®1638 is a low power dual rail-to-rail input and output operational amplifier available in the standard 8-pin PDIP and SO packages as well as the 8-lead MSOP package.
The LT1639 is a low power quad rail-to-rail input and output operational amplifier offered in the standard 14-pin PDIP and surface mount packages. For space limited applications the LT1638 is available in a 3mm x 3mm x 0.8mm dual fine pitch leadless package (DFN). The LT1638/LT1639 op amps operate on all single and split supplies with a total voltage of 2.5V to 44V drawing only 170µA of quiescent current per amplifier. These amplifiers are reverse battery protected and draw no current for reverse supply up to 18V. The input range of the LT1638/LT1639 includes both supplies, and a unique feature of this device is its capability to operate over the top with either or both of its inputs above
  • Тип ОУ: Low Power
  • Количество усилителей: 4
  • Полоса частот: 1.2 МГц
  • Slew Rate: 0.38 В/мкс
  • Диапазон напряжения питания: ± 1.5 В ... ± 22 В
  • Amplifier Case Style: SOIC
  • Количество выводов: 14
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: SOIC
  • Тип усилителя: Operational
  • Семейство: 1639
  • Gain Bandwidth: 1075 кГц
  • Вход / выход: Rail-Rail I/O
  • Input Offset Voltage Max: 1.05 мВ
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Напряжение питания номинальное: 22 В
  • Способ монтажа: SMD
Дополнительные аксессуары:
  • Fischer Elektronik - ICK SMD E 15 SA
  • Roth Elektronik - RE932-03
  • STANNOL - 631954
На английском языке: Datasheet LT1639CS - Linear Technology IC, SM, OP AMP, QUAD
