Datasheet LT1806IS6 - Linear Technology Даташит OP усилитель, RR I/O, LN, SINGLE, SOT23-6 — Даташит
Наименование модели: LT1806IS6
![]() 32 предложений от 20 поставщиков 325MHz, Single/Dual,Rail-to-Rail Input and Output, Low Distortion,Low Noise Precision Op Amps | |||
LT1806IS6#TRPBF Analog Devices | от 478 ₽ | ||
LT1806IS6 TRPBF Linear Technology | по запросу | ||
LT1806IS6#TRPBF Linear Technology | по запросу | ||
LT1806IS6#TRM Linear Technology | по запросу |
Производитель: Linear Technology
Описание: OP усилитель, RR I/O, LN, SINGLE, SOT23-6
FEATURES
n n n n n n n n n n n n n n n n
LT1806/LT1807 325MHz, Single/Dual, Rail-to-Rail Input and Output, Low Distortion, Low Noise Precision Op Amps DESCRIPTION
The LT®1806/LT1807 are single/dual low noise rail-to-rail input and output unity-gain stable op amps that feature a 325MHz gain-bandwidth product, a 140V/s slew rate and a 85mA output current.
They are optimized for low voltage, high performance signal conditioning systems. The LT1806/LT1807 have a very low distortion of 80dBc at 5MHz, a low input referred noise voltage of 3.5nV/Hz and a maximum offset voltage of 550V that allows them to be used in high performance data acquisition systems. The LT1806/LT1807 have an input range that includes both supply rails and an output that swings within 20mV of either supply rail to maximize the signal dynamic range in low supply applications. The LT1806/LT1807 maintain their performance for supplies from 2.5V to 12.6V and are specified at 3V, 5V and ±5V supplies. The inputs can be dr
- Тип ОУ: Precision
- Количество усилителей: 1
- Полоса частот: 325 МГц
- Slew Rate: 140 В/мкс
- Диапазон напряжения питания: 2.5 В ... 12.6 В
- Amplifier Case Style: SOT-23
- Количество выводов: 6
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: SOT-23
- Семейство: 1806
- Gain Bandwidth: 325 МГц
- Рабочий диапазон температрур: -40°C ... +85°C
- Способ монтажа: SMD
