Datasheet LT2078IS8 - Linear Technology Даташит ИС, OP усилитель, UP, DUAL, 8SOIC — Даташит
Linear Technology LT2078IS8
Наименование модели: LT2078IS8
33 предложений от 20 поставщиков
, Micropower, Dual and Quad, Single Supply, Precision Op Amps
LT2078IS8#PBF
224 ₽
LT2078IS8#TRPBF
1 002 ₽
Триема
LT2078IS8TRPBF
1 160 ₽
LT2078IS8 PBF
Производитель: Linear Technology
Описание: ИС, OP усилитель, UP, DUAL, 8SOIC
data sheetСкачать Data Sheet
LT 2078/LT 2079 Micropower, Dual and Quad, Single Supply, Precision Op Amps
FEATURES
s s s s s s s s s
DESCRIPTIO DESCRIPTION
The LT ® 2078 is a micropower dual op amp in 8-pin small outline, standard surface mount package, and LT2079 is a micropower quad op amp offered in the standard 14-pin surface mount package.
Both devices are optimized for single supply operation at 5V. ±15V specifications are also provided. Micropower performance of competing devices is achieved at the expense of seriously degrading precision, noise, speed and output drive specifications. The design effort of the LT2078/LT2079 was concentrated on reducing supply current without sacrificing other parameters. The offset voltage achieved is the lowest on any dual or quad nonchopper stabilized op amp­­micropower or otherwise. Offset current, voltage and current noise, slew rate and gain bandwidth product are all two to ten times better than on previous micropower op amps. Both the LT2078/LT2079 can be operated fro
  • Тип ОУ: Precision
  • Количество усилителей: 2
  • Полоса частот: 200 кГц
  • Slew Rate: 0.1 В/мкс
  • Диапазон напряжения питания: 2.3 В ... 12 В
  • Amplifier Case Style: SOIC
  • Количество выводов: 8
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: SOIC
  • Семейство: 2078
  • Gain Bandwidth: 200 кГц
  • Рабочий диапазон температрур: -40°C ... +85°C
  • Способ монтажа: SMD
На английском языке: Datasheet LT2078IS8 - Linear Technology IC, OP AMP, UP, DUAL, 8SOIC
