Datasheet LT6003HDC - Linear Technology Даташит OP усилитель, SINGLE, 1.6 В, 1UA, RR, 4DFN — Даташит
Linear Technology LT6003HDC
Наименование модели: LT6003HDC
27 предложений от 17 поставщиков
, 1.6V, 1µA Precision Rail-to-Rail Input and Output Op Amp
LT6003HDC#TRPBF
от 38 ₽
LT6003HDC#TRPBF
44 ₽
LT6003HDC#TRMPBF
от 319 ₽
LT6003HDC#TRMPBF
Производитель: Linear Technology
Описание: OP усилитель, SINGLE, 1.6 В, 1UA, RR, 4DFN
data sheetСкачать Data Sheet
LT6003/LT6004/LT6005 1.6V, 1µA Precision Rail-to-Rail Input and Output Op Amps FEATURES
n n n n n n n n n n n
DESCRIPTION
The LT®6003/LT6004/LT6005 are single/dual/quad op amps designed to maximize battery life and performance for portable applications.
These amplifiers operate on supplies as low as 1.6V and are fully specified and guaranteed over temperature on 1.8V, 5V and ±8V supplies while only drawing 1A maximum quiescent current. The ultralow supply current and low operating voltage are combined with excellent amplifier specifications; input offset voltage of 500V maximum with a typical drift of only 2V/°C, input bias current of 90pA maximum, open loop gain of 100,000 and the ability to drive 500pF capacitive loads, making the LT6003/LT6004/LT6005 amplifiers ideal when excellent performance is required in battery powered applications. The single LT6003 is available in the 5-pin TSOT-23 and tiny 2mm Ч 2mm DFN packages. The dual LT6004 is available in the 8-pin MSOP and 3mm Ч 3mm
  • Тип ОУ: Precision
  • Количество усилителей: 1
  • Полоса частот: 3 кГц
  • Slew Rate: 0.0013 В/мкс
  • Диапазон напряжения питания: 1.6 В ... 16 В
  • Количество выводов: 4
  • SVHC: No SVHC (15-Dec-2010)
  • Тип корпуса: DFN
  • Семейство: 6003
  • Gain Bandwidth: 3 кГц
  • Рабочий диапазон температрур: -40°C ... +125°C
  • Способ монтажа: SMD
На английском языке: Datasheet LT6003HDC - Linear Technology OP AMP, SINGLE, 1.6 V, 1UA, RR, 4DFN
