Datasheet LTC6079CDHC - Linear Technology Даташит Operational Amplifier (Op-Amp) ИС — Даташит
Linear Technology LTC6079CDHC
Наименование модели: LTC6079CDHC
31 предложений от 19 поставщиков
Op Amp Quad Low Noise Amplifier R-R I/O 5.5V Automotive 16-Pin DFN EP Tube / IC OPAMP GP 750KHZ RRO 16DFN...
LTC6079CDHC#TRPBF
104 ₽
LTC6079CDHC#PBF
194 ₽
T-electron
LTC6079CDHC#PBF
262 ₽
LTC6079CDHC/IDHC
Производитель: Linear Technology
Описание: Operational Amplifier (Op-Amp) ИС
data sheetСкачать Data Sheet
LTC6078/LTC6079 Micropower Precision, Dual/Quad CMOS Rail-to-Rail Input/Output Amplifiers FEATURES
DESCRIPTIO
Maximum Offset Voltage of 25µV (25°C) Maximum Offset Drift of 0.7µV/°C Maximum Input Bias: 1pA (25°C) 50pA (85°C) Micropower: 54µA per Amp 95dB CMRR (Min) 100dB PSRR (Min) Input Noise Voltage Density: 16nV/Hz Rail-to-Rail Inputs and Outputs 2.7V to 5.5V Operation Voltage LTC6078 Available in 8-Lead MSOP and 10-Lead DFN Packages; LTC6079 Available in 16-Lead SSOP and DFN Packages
The LTC®6078/LTC6079 are dual/quad, low offset, low noise operational amplifiers with low power consumption and rail-to-rail input/output swing.
Input offset voltage is trimmed to less than 25µV and the CMOS inputs draw less than 50pA of bias current. The low offset drift, excellent CMRR, and high voltage gain make it a good choice for precision signal conditioning. Each amplifier draws only 54µA current on a 3V supply. The micropower, rail-to-rail operation of the LTC6078/LTC6079 is well
  • Тип ОУ: Low Power
  • Количество усилителей: 4
  • Полоса частот: 750 кГц
  • Slew Rate: 0.05 В/мкс
  • Диапазон напряжения питания: 2.7 В ... 5.5 В
  • Amplifier Case Style: DFN
  • Количество выводов: 16
На английском языке: Datasheet LTC6079CDHC - Linear Technology Operational Amplifier (Op-Amp) IC
