Datasheet LTC6085CDHC - Linear Technology Даташит ИС, КМОП OP усилитель, 1.5 МГц, RR, 16DFN — Даташит
Наименование модели: LTC6085CDHC
![]() 17 предложений от 14 поставщиков IC CMOS 4 CIRCUIT 16DFN / CMOS Amplifier 4 Circuit Rail-to-Rail 16-DFN (5x3) | |||
LTC6085CDHC#PBF Linear Technology | 88 ₽ | ||
LTC6085CDHC#TRPBF Analog Devices | 187 ₽ | ||
LTC6085CDHC#TRPBF Linear Technology | по запросу | ||
LTC6085CDHC PBF Linear Technology | по запросу |
Производитель: Linear Technology
Описание: ИС, КМОП OP усилитель, 1.5 МГц, RR, 16DFN
FEATURES
n n n
LTC6084/LTC6085 Dual/Quad 1.5MHz, Rail-to-Rail, CMOS Amplifiers DESCRIPTION
The LTC®6084/LTC6085 are dual/quad, low cost, low offset, rail-to-rail input/output, unity-gain stable CMOS operational amplifiers that feature 1pA of input bias current.
A 1.5MHz gain bandwidth, and 0.5V/s slew rate, along with the wide supply range and a low 0.75mV offset, make the LTC6084/LTC6085 useful in an extensive variety of applications from data acquisition to medical equipment and consumer electronics. The 110A supply current and the shutdown mode are ideal for signal processing applications which demand performance with minimal power. The LTC6084/LTC6085 have an output stage which swings within 5mV of either supply rail to maximize signal dynamic range in low supply applications. The input common mode range includes the entire supply voltage. These op amps are specified on power supply voltages of 2.5V and 5V from 40°C to 125°C. The dual amplifier LTC6084 is available in 8-lead MSOP
- Тип ОУ: CMOS
- Количество усилителей: 4
- Полоса частот: 1.5 МГц
- Slew Rate: 0.5 В/мкс
- Диапазон напряжения питания: 2.5 В ... 5.5 В
- Количество выводов: 16
- SVHC: No SVHC (15-Dec-2010)
- Тип корпуса: DFN
- Семейство: 6085
- Gain Bandwidth: 1.5 МГц
- Рабочий диапазон температрур: 0°C ... +70°C
- Способ монтажа: SMD
